Back up camera or sensors
Ok for what ever reason my wifes 07 Limited EL didn't come with back up sensors or a camera. There's a lot of after market products out there. Some looks to be a pile of crap and some looks top notch. I was thinking a camera set up would be nice but then there is the wiring issue. Because of the drop down airbags lining the roof I would be hesitant run wires up there. I've seen a couple of wireless models? Has anyone tried anything yet?
I just ordered the Sanyo CCA-BC200 backup camera system.
It is really slick in that is uses a computer system to correct the fisheye image as well as projects lines for the width of the vehicle and foot markers at 2, 4, and 8ft behind the truck. It also has an arial view that looks like an overhead view showing the back of the truck.
With regards to the wires, there are aftermarket wireless video senders that you can use to send the video from the back of the truck to the front where the monitor is.
My 07 limited came standard with backup sensors that beep when you get close to something. I believe they can be disabled via the menu so if you don't hear any beeping when backing up (and you're close to an object), check the menu to see if you have it enabled.
fnx4wheeler
03-12-2010 06:57 PM
