Decode help..
Old Mar 9, 2009 | 04:58 PM
Ronzi's Avatar
Ronzi
Decode help..
Ok these are the numbers on the what I believe is the waranty plate. Its located on the left door under the latch.
F38SUFC4791
133 N F380 GA8 K 37A
08550 1979 450118
Its a metal tag held on by rivits. I tried to take a pic of it but it dont show up well in the photo.
Thanks in advance for any help.
Old Mar 9, 2009 | 07:31 PM
Holiver31's Avatar
Holiver31
Truck Series: F-3 Conventional
Engine: Unknown, Please double check VIN number
Assembly on: Unknown, Please double check VIN number
also what year is this pickup
Old Mar 9, 2009 | 08:44 PM
Jermafenser's Avatar
Jermafenser
F38SUFC4791
F38 - F-350 4x4 Chassis & Cab
S - 400 2v V8
U - Louisville, KY assembly plant
FC4791 - June, 1979
133 - 133" Wheelbase
N - Light Medium Pine
F380 - F-350 4x4 Chassis & Cab with 8550 GVW
GA8 - G - Leather Grain Bench Seat. A - Black trim interior. 8 - Chassis & Cab
K - Ford C6 transmission
37A - 5300lb Dana 60 3.54 open axles. A? I don't recall what was A...
08550 - GVW
1979 - model year
45 - DSO (Lansing, MI) 0118 - special order DSO code
Old Mar 11, 2009 | 06:23 PM
Ronzi's Avatar
Ronzi
Ooooppps !!
Forgot to say thank you.
Thank you !
Old Mar 11, 2009 | 06:50 PM
Dr. Dirt's Avatar
Dr. Dirt
37A
37 = Rear Axle: 3.54 5300lb Dana 60
A = Front Axle: ('78-79) P.S. w/adj col.
Old Mar 12, 2009 | 11:21 AM
Ronzi's Avatar
Ronzi
What is "w/adj col."
Old Mar 12, 2009 | 02:28 PM
Jermafenser
Originally Posted by Dr. Dirt
37A
That's it...even my truck has that code, and I couldn't remember.
Old Mar 12, 2009 | 02:29 PM
Jermafenser
Adjustable column AKA tilt steering.
Old Mar 12, 2009 | 03:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FRONT AXLE CODES ~ See: Page 59 in the General Information Text Section of the 1973/79 Ford Light Truck Parts Catalog.
REAR AXLE CODES ~ See: Pages 56, 57 & 58.
Holliver: The designation F-3 was not used after 1952.
Warranty Plate (& Certification Label) AXLE codes: If the code begins with a letter = LIMITED SLIP / If with a number, no Limited Slip.
This has been the case since 1959, and includes all the cars, Econolines, etc. as well.
Old Mar 12, 2009 | 06:00 PM
Holiver31's Avatar
Holiver31
yeah i was just throwin a guess out there on that one haha
Old Mar 12, 2009 | 06:33 PM
Jermafenser
Searching...found it. It was pages 59-62 instead in my edition.
Old Jan 16, 2010 | 07:07 PM
hayden1979f250's Avatar
hayden1979f250
NEED HELP PLEASE.
HEY GUYS! I JUST BOUGHT A 1979 F250. I WAS WONDERING IF U COULD HELP ME DECODE THE DOOR TAG. IM CURIOUS ON TRIM AND ORIGINAL PAINT COLOR.
133 O(OR C) F253 DB4 F 37J
07900 1979 28
THANKS FOR YOUR HELP.
Old Jan 16, 2010 | 09:00 PM
mikeo0o0o0's Avatar
mikeo0o0o0
WB 133=133" wheelbase
Color O (c)= O=Silver,C= Jade
Model F253= 7900 GVW F250 2WD
Body DB4= (DB)Ranger XLT Lariat Blue all vinyl (4) Ranger XLT w/ styleside box
Trans F= 4 speed Warner T18
Axle 37J= (37) 3.54 Dana 60 5300 lb capacity (J) w/ power steering
GVW 07900=7900 gross vehicle weight
DSO 28= Louisville district office
Old Jan 17, 2010 | 08:29 AM
BDawg171's Avatar
BDawg171
Where was a DSO 11 from?
Old Jan 17, 2010 | 09:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
DSO 11 was Boston district
