Fan Clutch Question - Full Engage When Cold
Recently the fan is fully engaged at start-up. This has not been the case with this truck until recently. This morning, the fan clutch did not disengage even while the truck was running at high idle while loading a Cat on the flatbed.
The clutch is not frozen. When the engine is shutdown, the fan can be rotated.
What could have caused this change? Bismic (I think) noted that the EGR system is involved with fan management. Could this be an early tell of EGR valve problems or is something else going on?
It is 40 degrees +/-.
Thanks in advance for your advice.
-Mike
-Mike
crucialprospect
10-03-2017 08:35 PM
dbuck50
12-04-2003 03:26 PM
