99 Ball Joints
Old Mar 9, 2009 | 07:05 AM
markdido's Avatar
markdido
99 Ball Joints
OK. The rubber boots on both the upper and lower control arms are shot.
I won't be able to replace the control arms until next month.
Is there some way to temporarily lube the ball joints to quiet the horrible squeaking when I turn the wheel or go over bumps?
Thanks!
Old Mar 9, 2009 | 11:13 AM
Rockledge's Avatar
Rockledge
As a temporary measure, I've heard of people poking a small hole in the boot (if there is not a hole already) and squirting some grease inside. Then clean the area real good and use a dab of silicone to seal the hole.
Look for the small tubes of grease at the local autparts store that have a pointed tip.
Old Mar 10, 2009 | 02:45 AM
markdido's Avatar
markdido
Boots are pretty much gone I'm afraid. I was thinking of some sort of spray lubricant. I might have to apply it daily, but it would beat listening to my truck creak and groan.
Old Mar 10, 2009 | 06:10 PM
machinist man's Avatar
machinist man
I actually did this yesterday on my 2000. The upper joint on the pass. side has a torn boot, and it was creaking everytime I turned the wheel. I just shot it full of grease and secured the boot as best I could. The squeaking stopped, it's amazing how annoying that kind of noise can get after a while.
Old Mar 10, 2009 | 07:01 PM
therealulysses's Avatar
therealulysses
Are there any grease fittings or places to connect grease fittings on those? I have squeaks on my '97 Explorer and couldn't find any place to grease it other than squirt some grease inside the boots as mentioned.
Old Mar 11, 2009 | 02:20 AM
markdido's Avatar
markdido
I don't believe that Ford ships vehicles with grease fittings. You can have them installed later, which doesn't make any sense to me.....
Old Mar 11, 2009 | 09:57 PM
drb1956's Avatar
drb1956
My '99 Ranger did not come with grease zerks,(puchased used in 2002 with 47,000) but I was changing the oil and checked the front end for lube-ended up I drilled 1/8 inch holes in the top of the upper ball joints, and the same on the lowers, and installed zerks-130,000 around the corner with the original ball joints, but at last oil change I noticed one the uppers has a tear in it, so it looks like I'm in for a replacement..........
