Try to answer these questions! 302 with issues...
#31
Help! 198 Ford F150 issue
I have an '87 F150 V6 300 which when cold has started idling rough. If I leave my foot slightly on the gas for about 15 seconds it smooths itself out and if I give it a bit more gas for a quick second it idles like normal. It does it on both tanks and if I turn it off and let it sit for about 10 mins or so it starts back up without issues. However, give it about 30 mins ago it fires back up and runs just a little rough but smooths out again. Not sure exactly where to start looking.
#32
#33
Welcome to FTE Prodigy826.
Unfortunately, there was never a V6 300. This post was originally for a different problem.
I would start by posting a New thread, and explain your problem there.
As far as your problem, I would suspect your IAC maybe sticking. You can clean it with MAF cleaner, Isopropyl alcohol, electronic cleaner, etc. with a Q-tip. Otherwise, checking for codes is the 1st step.
Just post a new thread detailing your problem.
HotFuzz
11-21-2015 01:54 PM
lazzarruss
11-21-2013 04:30 AM
