e4od question
Old Mar 6, 2009 | 01:29 AM
rupejosh's Avatar
rupejosh
e4od question
can you pull a tach sensor off another truck with an e4od even if its a gas motor?the junk yard here sells them for $4 if so im going to go get them all.
Old Mar 6, 2009 | 01:36 AM
David85's Avatar
David85
The diesels use a magnetic pickup for the tach signal, so I don't think it would work. With a gasser, its usually just a wire off the ignition coil. At least thats how the older ones worked.
I'm trying to figure out what you are refering to for a "tach sensor". Is it a camshaft sensor or something like it?
Old Mar 6, 2009 | 03:17 AM
rupejosh's Avatar
rupejosh
its the sensor behind the vaccum pump with two wires coming out of it
Old Mar 6, 2009 | 08:10 AM
jas88's Avatar
jas88
I think he means what tach sensor are you talking about on a gas motor.
Old Mar 6, 2009 | 01:48 PM
David85's Avatar
David85
Correct...
Old Mar 7, 2009 | 12:08 AM
ford trans tech's Avatar
ford trans tech
gas engines do not have a tach sensor
Old Mar 7, 2009 | 04:14 AM
rupejosh's Avatar
rupejosh
well crap.lol thanks guys
