cold start help
Old Mar 5, 2009 | 03:52 PM
Dan Taylor's Avatar
Dan Taylor
cold start help
im stuck at school and cant get the truck to turn over. ive tried getting a boost from another car and still not enough power. i threw a bottle of isoheet in last nite and put one of the batterys in the cab to try and keep it warm. should i check for gell in the fuel filter? maybe 2 car boost for each battery? any ideas would help. also there is no plug to plug the heater into to
Old Mar 5, 2009 | 04:00 PM
superduty4x4's Avatar
superduty4x4
If you are using a gasser to jump-start, it's gonna take a while with the cables hooked up especially if your batts were completely dead. 2 rigs, one on each battery for no less than 5 minutes before you hit the key.
Old Mar 5, 2009 | 04:02 PM
Mike Norwood's Avatar
Mike Norwood
Dan, where are you? What are the temps? How heavy are the jumper cables?
Old Mar 5, 2009 | 04:15 PM
Dan Taylor's Avatar
Dan Taylor
not sure on the cables but im over by capecod. it was around 32 today. i could get the starter going but not enough to turn over. ill find 2 cars tom. to give me a boost. tom. is also suppose to be around 45 deg. which should help. any other ideas?
Old Mar 5, 2009 | 04:21 PM
Mike Norwood
Is it possible to plug the block heater in? With those temps it also sounds like you may have bad batteries. My block heater plug has been shorted out for the duration of the winter and lazy me hasn't fixed it yet. I have started my truck in the single digits without having to be jumped or having it plugged in. The question about the cables was because these trucks take a lot of amperage to turn over properly and with light, cheap cables you will probably not get enough amperage to do the job. Been there done that with cheap cables.
Old Mar 5, 2009 | 04:28 PM
Dan Taylor's Avatar
Dan Taylor
ya im just in a parking lot with no outlets. the batterys always start the truck fine if its above 45. it may be time for some new ones. the truck did sit in single digit weather for 60 days over the winter but has done 600 miles since then starting up fine. if this happens again once i get it going ill try new batterys
busabuggy
Jan 1, 2019 09:32 PM
2006powerstroke90
Nov 17, 2011 06:50 PM
Stuffengineer
Mar 6, 2006 05:50 PM
dlevey
Nov 24, 2004 10:35 PM
