1961 Ford Truck F100 Frame dimensions
Didn't find '61, but '64 should be pretty similar, other than the LWB chassis WB being 128" vs '61 being 122" Both years are straight axle, both years had I-6's or Y-block V8....besides wheelbase, the other difference that comes to mind is '61-'63 had three bolt bumpers, while '64 was first year of two bolt bumpers....
**there are people selling frame diagrams on ebay
SWB (114")
http://www.fordification.info/tech/i...f100swb_01.jpg
http://www.fordification.info/tech/i...p3_f100swb.jpg
LWB (128")
http://www.fordification.info/tech/i...00250lwb01.jpg
http://www.fordification.info/tech/i...00250lwb02.jpg
SWB (114")
LWB (128")
Tommie: Well, I guess EBAY may be your best option, a quick look didn't bring up any listings for 1961, but did find listings for 1963/64....
.........but even with Frame Charts, I'd be a lot more comfortable sending it out the door AFTER having test fit the front clip. If the horns are a wee bit low, things can be shimmed, but if they're a wee bit high, it's not so easy. (former A/B Mechanic from 1979-1990)
SWB 2WD (114")
https://www.ebay.com/itm/1963-1964-F...cAAOSwtM9cyP75
LWB 2WD (122")
https://www.ebay.com/itm/1963-Ford-F...cAAOSwtM9cyP75
HTH
James
SWB 2WD (114")
LWB 2WD (122")
HTH
James
JTB321
06-26-2017 04:20 PM
