Will this Summit Alternator bracket fit my application?
1993 F150 5.0 EFI 4x4
Summit SUM-420104 - Summit® Chrome Alternator Brackets - summitracing.com
I'm looking to eliminate my smog pump so will this part work?
If it mounts like my 89 F150 with 300I6, the style looks right. However there are two critical measurements to account for. The most important is will it push the pulley into line with the crank. I see some shims, but using shims will make it more susceptible to flexing and moving the pulley out of alignment. The other measurement is if the bolt holes will line up with anything. You can fudge them a little with some of your own brackets but it will not look as pretty.
I'd check with March, summit doesn't actually manufacture anything, they use "white box" products from other manufactures. I'd bet that this is either made by or designed to be identical to March's offerings. March Performance Serpentine Systems Pulleys and Brackets
Water_Boy
1999 to 2016 Super Duty
02-22-2013 01:13 AM
Bluethunder3320
09-14-2012 09:35 PM
ManfredVonRichtofen
05-30-2012 02:38 AM
hav24wheel
07-26-2011 08:27 AM
wildstang
22
11-26-2009 10:58 AM
