Feel / Hear shudder after MBRP install
I had the turbo-back MBRP exhaust installed on my truck last weekend. Ever since the exhaust has been installed I hear a shudder sound.
This doesn't happen constantly. When I'm sitting at idle I hear a cyclical sound that sounds like a vibration or shudder. This could be due to the exhaust pipe touching a bolt under the frame - so I'm not really worried about that.
What does concern me is when I turn the truck off it makes a shutter sound/feeling right before the engine stops running. It's like the very last sound before silence from the engine (or from the turbo, whatever) is this shudder sound/feeling I've never heard/felt before.
Anyone else ever experience this right after installing an aftermarket exhaust?
I've been searching and reading quite a few people experienced this same shudder when turning off the truck after installing a custom exhaust. That at least helps me feel like I'm not crazy and it isn't anything MAJOR wrong with the truck.
Now...if I can just find out WHERE this dang exhaust is rubbing - maybe it's just that 1 spot under the cab where the pipe rests on a bolt on the frame. I'll also check around the down pipe as that seems to be a common cause of this shudder.
Mine hit in the same place. Not sure about your other issue you are having. Cant imagine its your exhaust doing it.
wyomingbs
05-29-2013 05:14 PM
t4kne
35
11-21-2003 10:06 PM
