ok, I know that ive seen this discussed in here before. 2005 F-350 PSD, 6 disc in dash changer. the aux input, what do i need to connect an i pod to the aux input? i cant seem to find it in the forums. thanks for the help.
cheers
matt
FRD-04 PIE and a UNI-POD. You can add a couple of RCA splitters and put in a 3.5mm male or female jack in the system too. This will let you plug into the iPod thru the headphone jack, or the UNI-POD has a cable that will connect and charge the iPod as it plays. I used this system and it worked great. The only thing I didn't like was that I couldn't find the wire (power delay) that keeps the radio on with the key off till you open the door. I prefer to scroll thru the iPod as it is playing, the Brandmotion does not let you do this, but it scrolls the text across the stereo.
thanks got the stuff on order. decided not to get the one that charges the ipod in an effort to make the install look clean with just a female 3.5mm jack on the dash. thanks again for your help.
cheers
matt
