Sponsored by: Real Truck
Headlight?
Old Mar 4, 2009 | 04:34 PM
Furian's Avatar
Furian
You Keep What You Kill
Originally Posted by ReAX
I wouldn't even attempt to do it on the stock wiring, you'd be pulling twice the amperage through the headlight switch and associated wiring. You can build a relay harness rather cheaply, and the 9008 use an easily available socket. Then bridge the relays so voltage from the high beam relay's coil can flow across a diode into the low beam relay's coil. Thinking off the top of my head, if you use a SPDT relay, use 30 to feed the sockets, then on the high beam relay, run the 87 to the high beam pins and jump it across to the 87a on the low beam relay.
Wow... I almost saw that but it was so far over my head! And I'm not kidding... I need to take an electrical class at the local community college!
Old Mar 4, 2009 | 09:49 PM
ReAX's Avatar
ReAX
If you want to learn 12v, there are MECP schools and I highly recommend Installer's Institute in Holly Hill, FL. I could dope out a relay before, usually working off the little diagram on the housing. Now, I can work them in my head, plus they teach a little of ohm's law, how to use a DMM. You can pick up a copy of the MECP text book on ebay and other places too.
Old Mar 4, 2009 | 10:04 PM
Furian's Avatar
Furian
I understood "12v" and "ebay" in your last post... I'm an electrical dumba$$!
Seriously, I would like to take a basic electrical course just to be able to install goodies on my vehicles and perform basic maintenance around the house. I'm sure that there are courses available at the local community college that's only 4 miles away. I appreciate the information and maybe one day I'll be able to understand your "electrical" related posts.
Old Mar 4, 2009 | 10:12 PM
ReAX's Avatar
ReAX
MECP (Mobile Electronics Certified Professional) is MERA's (Mobile Electronic'ss Retailer's Association) attempt to create a standard of knowledge for installers. It's based around car audio a little more than I would like, but it was a heck of an education for me. Just reading the small text book was incredibly helpful.
Check out the cheat sheet and DMM primer I made up. There are a few tricks and a little good knowledge.
Old Mar 4, 2009 | 10:14 PM
DAVE67FD's Avatar
DAVE67FD
Most of your local community schools/colleges offer night classes at certain times during the year on basic electricity/electronics.
Old Mar 4, 2009 | 10:15 PM
Furian's Avatar
Furian
Where can I find the "cheat sheet and DMM primer" resources?
Old Mar 4, 2009 | 10:17 PM
Furian's Avatar
Furian
That's what I was thinking of doing... I would even be interested in a focused 2-6 week course. My motivation is for personal growth and self-reliance.
Old Mar 4, 2009 | 10:25 PM
ReAX's Avatar
ReAX
In my signature, I have a link for tech write-ups. It should take you to a google hosting page where I have four PDFs.
Old Mar 4, 2009 | 10:31 PM
CityGuy24's Avatar
CityGuy24
Hey, thanks for all the info. So if I wanted to get a set of HID's how hard would they be to install?
Old Mar 4, 2009 | 10:49 PM
Furian's Avatar
Furian
Ah... I see them now. Thanks!
Old Mar 5, 2009 | 08:37 AM
Citypol86's Avatar
Citypol86
I went with these, what do you think? They should be heavy enough I think.
1.5KE15A
Thanks for the help, too, I've never been to one of those classes, I just learn as I go. I am going to check out that book though. That sounds like just what I need. I don't need official cert.'s, I need the knowledge.
Thanks again,
Later...
Brewster...
Old Mar 5, 2009 | 08:46 AM
Futuresweets-10's Avatar
Futuresweets-10
It would require a diode and be pushing the limits on some plugs. At 55watts your near 5amps, double that to 10A and you will be pulling all 10A through the ground plug. Plus your going to producing more heat than intended from the filaments. My relay harness should handle 15A per headlight pin, but I am not so sure of the bulbs.
Ive done this on several vehicles and no Diode, although it does require two relays. I never use a diode in automotive applications if I can avoid it.
You will need to find the positive wire for the low beams, cut it and connect the wire going to the bulb to pin 30 on the relay. The other end of the wire goes to 87A. You will need to connect 87 to a 12v source (fuse this wire). 85 needs to be connected to ground an 86 connects to the positive wire of the your high beam(wise idea to fuse this as well. When the lights are on low beam the voltage will travel through the relay as if it were not even there. When the high beams are turned on the relay will energize and then connect the low beam bulb to the 12 volts from the battery. You will have to do this on each light.
Old Mar 5, 2009 | 06:22 PM
  #28
Citypol86's Avatar
Citypol86
Originally Posted by Futuresweets-10
You will need... You will have to do this on each light.
Hah! That's much easier! RP sent!
An added plus is that the direct power give the low beam extra brightness when High beams are on.
Later...
Brewster...
Old Mar 5, 2009 | 08:01 PM
  #29
akford351's Avatar
akford351
Xtravisions are the brightest bulb you can get... I wasted money on the Silverstars.
HIDs are much brighter than any bulb you can get though.
Old Mar 5, 2009 | 10:40 PM
  #30
Citypol86's Avatar
Citypol86
Want bright?!? Susquehanna MotorSports - Detail 100/80watt bulb... Read the caveat though.
Later...
Brewster...
