What do you use to clean your parts? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-02-2009, 08:42 PM
murph77's Avatar
murph77
murph77 is offline
murph77 is starting off with a positive reputation.
Originally Posted by 2classics View Post
50/50 simle green and water does pretty good with greasy/oily, but you may need to use more than one application. Best part is it's biodegradable. Gasoline varnish, I use gunk carb cleaner in a one gallon can.
Simple Green is great. I found this stuff before I had my license, when I discovered wrenches and started tearing apart bicycles as a kid. Still swear by it. Something to keep in mind, simple green itself is biodegradable, however once it has done it's work it is full of oily greasy grime... not biodegradable anymore. Anyway...
the stuff I have on hand for cleaning parts
simple green
carb cleaner
brake cleaner
pb blaster
mineral spirits
gasoline
Old 03-02-2009, 09:04 PM
DNFXDLI's Avatar
DNFXDLI
DNFXDLI is offline
DNFXDLI is starting off with a positive reputation.
Parts washer with mineral spirits and a brush.....glass beads for blasting.
Old 03-03-2009, 09:15 PM
410 Highboy's Avatar
410 Highboy
410 Highboy is offline
410 Highboy is starting off with a positive reputation.
I use stodard (sic?) solvent in a $50 parts cleaner from Summit .
Old 03-03-2009, 11:19 PM
Bgasrickshaw
Bgasrickshaw is offline
Bgasrickshaw is starting off with a positive reputation.
For heavy grease & crud (engines, trannys, axles, etc.) I use Easy-Off oven cleaner, the trigger spray bottle, not the spray can. It's cheap, and it cuts grease like nobody's business
Old 03-03-2009, 11:33 PM
Ranger76's Avatar
Ranger76
Ranger76 is offline
Ranger76 is starting off with a positive reputation.
Ahhh, PB Blaster, thats some awesome stuff outright in any appilcation.
And oven cleaner, wow I never would have thought off that.
Also, old toothbrushes are great for getting in tight spots.
Old 03-04-2009, 02:08 AM
Don S.'s Avatar
Don S.
Don S. is offline
Don S. is starting off with a positive reputation.
Freon Fogging tank.
Old 03-15-2009, 12:03 PM
classicfordman
classicfordman is offline
classicfordman is starting off with a positive reputation.
ill use any thing that gets the job done for me...lol
Old 03-15-2009, 04:20 PM
sfu7274456's Avatar
sfu7274456
sfu7274456 is offline
sfu7274456 is starting off with a positive reputation.
Oven Cleaner is the best for engine compartments. Just keep it off the paint. It will wash away any wax, and possibly burn the paint.
Old 03-15-2009, 08:36 PM
tenforty_2's Avatar
tenforty_2
tenforty_2 is offline
tenforty_2 is starting off with a positive reputation.
Originally Posted by Jermafenser View Post
What is AFT?
If I'm rebuilding a carburetor, I use carb cleaner, then kerosene.
All others, I use Castrol's heavy-duty degreaser and/or kerosene.
For rusted parts, I use a plastic tub with water and a battery charger.
OK.......I was hoping someone else would ask, but I guess I am the only one that don't know. Please explain the water and battery charger. I had some rusty parts, filled up a tub with some water, plugged up my battery charger, threw it in the water and it kicked my breaker! Can you help? Just kidding.....
Old 03-15-2009, 08:44 PM
Jermafenser
Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
I hope you were joking!
it's rust removal via electrolysis.
Here's a page on doing it.
http://www.secondchancegarage.com/pu...st-removal.cfm
Google search "electric rust removal" resulted in several hits. Do your research, and be safe!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
