Washer Fluid Reservoir/Warning Light
Hey all,
Just wanted to run this by you.. couldn't find it after a few quick searches.
I've noticed the my washer fluid warning light comes on and the washer fluid won't come up shortly thereafter.. which is completely normal, but when I go to fill up the reservoir, it still looks to be about half full! The first time it happened, I thought it might be a fluke, but then it happened again this weekend.
Is this normal, or do I have some sort of sensor and/or suction problem?
I was going to say if I let mine run down to the point where nothing comes out anymore when I use the sprayer, it will ALMOST but not quite take a full gallon if I fill it right to the top of the fill spout. But even then it still leave some in the gallon jug. I usually get quite a bit of use out of it even after the light comes on.
JWA
05-06-2021 03:18 AM
SVTDriver97
31
11-23-2018 07:02 AM
