high pressure oil system failure
Old Feb 26, 2009 | 11:53 PM
Eric_F250's Avatar
Eric_F250
halfway to work this morning, i blew a hole in one of my high pressure oil hoses- popped right through the stainless braided sleeve! lost oil pressure and the thing died right away.
it looked like i had simply poured five gallons of oil all over the engine like syrup on a flapjack.
an $80 tow and $300 in new parts and i was good to go, or so i thought. as i was driving it away from the shop, i noticed i had the most crappy steering imaginable. i took it back and we figured out that the steering gear box was shot. best we can figure is the combination of me going 75mph at the time, no power assist on steering after hose failure (due to engine shutting down), and me pulling over to the roadside was enough to strip the gears out. so i get to spend another $350 tomorrow. sweet.
anyone had a similar experience? the truck cranks and cranks before starting now, when before it would fire right up- air? any hints on recovering from the oil soaking? other things to watch for?
thoughts? comments? condolences?
-e
Old Feb 27, 2009 | 12:43 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
its gonna take it a while to start till the air gets out just drive it hard
Old Feb 27, 2009 | 01:25 AM
RubberDuck's Avatar
RubberDuck
Eric, it will take time for the air to get out. Just run the weeee out of it. As far as cleaning, lots of degreaser, and low pressure water. Alot of people like the simple green, but it will leave a white film on everything.
Old Feb 27, 2009 | 06:17 AM
jeep1947's Avatar
jeep1947
Eric, I use Super Clean get it at wal-mart use it on warm engine full strength to get all the mess off I use a garden hose with a good nozzle, just watch alternator, IDM and other electrics. Does a good job and leaves no residue.
Old Feb 27, 2009 | 06:50 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Been there...
But I blew the fitting out of the HPOP, stripped the threads right out of it. I was on some back roads so I just coasted off to the side. No steering trouble, but I had oil drip from my inner fender for almost 6 months, no kidding!
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 27, 2009 | 11:28 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
ditto on the cranking. it will take a few miles (50-100) to work all the air out of the system. been there. i had one of my hoses get a hole because it rubbed through on the fpr (i rerouted the hpo hose for the hpx mod) so it was my fault. lesson learned. make sure the hose isn't rubbing on anything.
Old Feb 27, 2009 | 11:46 AM
bmxstreet15's Avatar
bmxstreet15
i dont buy the steering box bs. I just blew my pressure line clean out of my power steering pump and had to drive 15 miles w/o power steering. when I got to autozone I purchased a new line and changed it on the spot. Took about 20 minutes and a quart of fluid. My box is fine. Mine actually seems to steer smoother/better after the line was replaced. As for the oil system, it takes time to bleed the air out, I use engine brite and a garden hose. and non-chlorinated brake parts cleaner for the hard to reach places.
Old Feb 27, 2009 | 12:08 PM
Neal 97 250's Avatar
Neal 97 250
$80 tow yes
But $300 in parts. What did you replace? I would just think hose(s) and they are not that expensive.
Old Feb 27, 2009 | 12:49 PM
BlueMule's Avatar
BlueMule
I ain't buying the steering box story either. With that much oil all over the engine compartment I bet the belts and pulleys all got oiled and the belt is just slipping on the power steering pump.
Old Feb 27, 2009 | 02:03 PM
Eric_F250's Avatar
Eric_F250
got it back from the shop just now. the hose i needed came as part of a kit i guess that both hoses, other seals, and galley plugs (so i was told). shopping for the hoses alone last night online i found the hoses for 279, so the 300 for those and other thingies sounded not too bad.
as for the steering box... the oil soaked pulley was what i thought of first too, but with engine off and wheels straight we observed a LOT of motion in column all the way down to the box that translated to zero motion out of the box. we are talking like 90 degrees to each the left and right before moving the arm that comes out of box.
steering already had a few inches of play anyhow, so i think it had been on its last legs for some time. the new one works great, although i have to say i got used to the loose steering and now the tighter action feels weird.
Old Feb 27, 2009 | 06:29 PM
glasseater's Avatar
glasseater
probably just really weird timing with the steering box...
as for the HPOP, it will take a couple HARD miles... took mine over 100 miles driving hard to clear it up completely
Old Feb 28, 2009 | 06:36 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Now that I think about it, I drove the truck home about 4 miles once with a cracked ps pump bracket and no belt at all, no steering or anything. No problems with the box...
Also, each high pressure oil line cost about $80, I have no idea what the Kit is they are referring to...
__________________
Old Feb 28, 2009 | 08:22 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Hope this never happens to me! Good to know ahead though.... Hope things work out...
That steering thing sounds real fishy. I agree with Jim and Rodney. It's probably just the belt slipping. Those boxes are real tough.
Old Feb 28, 2009 | 10:51 AM
Eric_F250's Avatar
Eric_F250
coincidence- maybe. bad box- definitely. lots of motion going into box and none coming out.
no moral to this story really other than now i know what the powerstroke engine cover is for. had i had that mounted up, i could have saved 12 bucks at the u-wash-it! i think i got 90% of the oil all cleaned up. it's starting better now, and runs well.
Old Feb 28, 2009 | 01:11 PM
RubberDuck's Avatar
RubberDuck
The moral of this story is ask the forum for help first. I've got about 10 hpop lines in the shop just collecting dust. And would have been happy to send you one. LOL But I understand your situation. Just glad you got it fixed.
