Hole in underhood insulation???
Old 02-22-2009, 04:36 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Went out to check the fluids in my truck for the start of the week and noticed a hole or indention in the under hood insulation. It's near center left to right and lines up right above the serpentine belt. No visible issues with the belt that has been on there for the last 83k miles. Anyone have ideas?
Old 02-22-2009, 04:43 PM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
The only thing I can think of is you were behind someone (at some time) that either lost some gravel/pebbles/etc or bounced a little bit up. It took a bounce under your radiator and got caught in the serp and slung into the blanket. Check your fan blades.
Man, seeing that would really baffle me and force me to spend a day under the hood...
Old 02-22-2009, 04:44 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
same place as mine..but mine was from the belt..maybe something got tossed up by the fan???
Old 02-22-2009, 07:42 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Maybe what ever chewed up you oil fill cap is living in there!!!!
Old 02-22-2009, 07:44 PM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
Its those darn gremlins!
Old 02-22-2009, 07:45 PM
F350-6's Avatar
F350-6
F350-6 is offline
Good memory Jim, but that's a scary thought because it means that things getting bigger
Old 02-22-2009, 07:46 PM
megawatt00's Avatar
megawatt00
I thought that everything in Texas was bigger...
Old 02-22-2009, 07:58 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Chris, looks like it came from the drivers side and hit hard. I wonder if that is the result of me and Roland throwing that injector at you when you left here?????
Old 02-22-2009, 08:02 PM
jdecker88's Avatar
jdecker88
jdecker88 is offline
jdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to behold
Throwing injectors around dang boys those things are worth good money! I agree it looks like something came off the fan and hit, but surely you would have heard something like that.
Old 02-22-2009, 08:10 PM
F350-6's Avatar
F350-6
F350-6 is offline
Rick, something tells me you would have thrown those tiny beers before you threw any injectors that you had a core charge on
It looks to me like the belt broke and the end slapped the hood since the hole is about as wide, and directly above the belt. Of course since I've had this truck since new, I'm on my 3rd belt, and I haven't broken one yet.
I do drive on gravel roads every day, but that's too square of an edge for gravel in my opinion. I guess I picked up something else or left a wrench or something under my hood.
Now I've got to try and remember what the last thing I did under my hood was and see if I'm missing any tools.
Old 02-22-2009, 08:32 PM
miller_feed
Chris, how can you be so wrong, I will never throw a beer away.
Old 02-22-2009, 10:14 PM
mueckster's Avatar
mueckster
mueckster is offline
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
I can vouch for that!
Old 02-23-2009, 07:49 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
Any idea on where to get a replacement hood mat? Mine at one time has stringing on the fan belt which made a nice slit across the front. Now it is sagging and contact glue holds nothing. I really need to replace it. Any part #'s or where to get a replacement? Thanks
Old 02-23-2009, 08:01 AM
F350-6's Avatar
F350-6
F350-6 is offline
Check with Ed (FTE Parts Guy) when he gets back from vacation. He'll be able to get you a part number and tell you if it's worth buying it from him or just getting it at your local dealer.
Old 02-23-2009, 08:59 AM
vettdvr's Avatar
vettdvr
vettdvr is offline
Ed did a nice job on my last interior parts order,, I will check with him.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
