2002 f-350 crew cab horn location?
Old 02-22-2009, 04:09 PM
timhugg's Avatar
timhugg
timhugg is offline
timhugg is starting off with a positive reputation.
Hi,
I want to install my air horns in this truck, But I cant find the old ones. Any ideas?
Thanks,
Tim
Old 02-22-2009, 04:17 PM
03F2507.3
03F2507.3 is offline
03F2507.3 is starting off with a positive reputation.
I have triple trumpet train horns mounted to my passenger side frame rail just behind the cab. Theres enough room to mount the horns, tank and compressor all to the frame.
Good luck...
Old 02-22-2009, 04:28 PM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
Can you take pics of the install please?
I am most interested in how you are protecting the compressor from the "outside world".
This is the only thing stopping me, as I do not have a CC with room behind the seat.
Thanks!
Old 02-22-2009, 04:37 PM
03F2507.3
I will try to get under there for photos as soon as I can. Im not sure what kind of compressor you have but mine has been fine for almost two years. I drive through water on my hunting lease that definately gets it nice and wet.
Horns go in first facing forward about 1 foot behind the cab on passenger side. I chose passenger because fuel lines run on the drivers side and the passenger battery has no extra connections while my drivers side bat is loaded up. Mark your holes and drill the frame. Make sure you have the correct bit for steel and use wd40 to cool it off as you drill. Wear safety goggles, you will get shavings all over you. Then the compressor just behind it. Last mount the tank at an angle because theres not enough room to mount it parallel to the frame. I only got three out of four holes for the tank but it is plenty secure. Run the wires and youre good to go.
Old 02-22-2009, 04:47 PM
timhugg's Avatar
timhugg
timhugg is offline
the train horns are fine and dandy stories fellas, but the question was, where are the factory horns located?
Old 02-22-2009, 04:53 PM
CharGriller's Avatar
CharGriller
CharGriller is offline
CharGriller has a very good reputation on FTE.CharGriller has a very good reputation on FTE.CharGriller has a very good reputation on FTE.
Originally Posted by timhugg View Post
Hi,
Thanks,
Tim
FTE Recommended method for OEM horn Location:
A. Raise hood.
B. Stick head under hood.
C. Have assitant honk existing OEM horn.
D. Use hearing to locate sound source.
E. Repeat as necessarry.
I'm sorry the devil made me do it!
Old 02-22-2009, 04:55 PM
Steve_250's Avatar
Steve_250
Aw gee Tim, sorry bout that. I read air horns and mistook it for train horns. Check alongside the radiator, they will most likely have the opening facing down.
Old 02-22-2009, 05:01 PM
Automator's Avatar
Automator
Automator is offline
Automator is gaining momentum as a positive member of FTE.
O believe they are on the passenger side under the fender behind the battery. IIRC, I had to take out the passenger battery and windshield fluid tank to fix mine.
Old 02-22-2009, 05:32 PM
timhugg's Avatar
timhugg
timhugg is offline
thanx guys
Old 02-22-2009, 05:42 PM
03F2507.3
Me too, sorry about that
Shadowrider123
06-17-2015 01:18 PM
GormGorm
04-04-2010 11:21 PM
TimmyAbrams
1978 - 1996 Big Bronco
15
02-20-2008 07:10 PM
Popa Tim
11-24-2005 10:28 AM
wicked5ltr
05-24-2004 11:30 AM
Quick Reply: 2002 f-350 crew cab horn location?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
