Fog lights
1. I have found the wiring harness at the left headlight, do both lights plug into that one connection?
2. Does Ford make a wiring harness that connects the lights to this connection?
3. Do i need to put in fuses and or relays?
4. My truck does not have the fog light switch with the headlights/parking lights, how will this work?
Pictures are GREATLY appreciated because i can not find any pictures on this topic. Thank you
My guess is you don't have the options in your harness for connecting the fogs as well as not having a harness for the lights themselves. Someone else may confirm this. I didn't on my 06.
You will have to wire up to your own supplied switch/relay.
Correctly wire and fuse the circuit.
You will have to trim the housing a little and tweak the latch.
If you don't want to do that, use the SS 9005, they fit but not as bright.
Run a hot lead (12 GA) to both lights to a relay near the battery. Attach the 12 GA to the relay along with the batt 12 GA. Run a line from a switch inside to the relay to activate it. That's about all there is to it. Oh, don't forget a fuse or breaker inline.
), i love them, imo looks bad azz this way.
