5 oil leaks Help
Old Feb 23, 2009 | 09:44 AM
jmaskew's Avatar
jmaskew
Originally Posted by Wyatt66f100
its not your master cylinder. hydroboost runs off of the power steering fluid, correct. if its leaking it could be the hydroboost or just the plastic sealing o rings on the high pressure power steering lines to the hydro boost are blown out. i dont usually see hydro boost units go out. just the o rings that seal the lines into the hydro boost unit. have you had any work done to it where they had to remove the cab? if you have then the last guy probably didnt replace them. id still take it in and yes it is covered on warrenty. i just ran the part number on oasis. good luck! hope it gets fixerd soon. -6.0L tech
1 1/2 years ago my head gaskets were replaced and they did lift the cab. I am making an appointment this morning for the egr cooler so I will have them look at it. Thank you for your great knowledge!!
Old Mar 16, 2009 | 09:19 PM
abmorejon's Avatar
abmorejon
I have the oil leak problem. Been to the dealer 5 times, changed all seals, rear engine cap, and still have leak. Really beginning to hate my ford, though it looks good. Anyone replaced an engine due to continuous oil leak?
Old Mar 29, 2009 | 08:01 PM
abmorejon's Avatar
abmorejon
I have been to the dealer 6 times for my oil leak. One visit even found my differential leaking at only 25000 miles. Still have a hanging drip which doesn't fall. Will continue to take it in since I have warranty which covers it and even gives me a loaner car.Love the Ford Truck, but beginning to see that oil leaks will always be with me.
Old Apr 10, 2009 | 08:32 PM
BigRed03's Avatar
BigRed03
Well, my 6.0 is in at the Ford doctor. Bed Plate being replaced. Had the hanging on for dear life oil drip, but figured under warranty so why not. Doesn't sound like a big deal, but always wonder when the cab is taken off, etc. Took it in the other day to have dome dye put in the oil, the tech said that the dye doesn't really work..(i have my thoughts on that), said better to get under and take a look. CMP Sensor O-rings and CAC Tube clamps already replaced (used dye there). So will see how it turns out. Even gave me a rental car to use. Anything I should look for after I get it back besides dirty finger prints on the cab? 2007 F-250 C.C. Lariat 06 Engine, Cab date 6/06. Will post again if anything goes wrong.
Old Apr 10, 2009 | 09:59 PM
abmorejon's Avatar
abmorejon
My cab was also lifted (so they say), hardly notice anything different but the darn hanging oil drop. Been there done that five times already and will continue till the warranty runs out or find myself a lawyer to have them either replace the engine or buy the truck back. Love the truck but my driveway is looking pretty bad with spots.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 10, 2014 07:20 PM
gdgrl711
Jul 4, 2014 07:41 AM
JessieDM
Apr 24, 2011 09:59 PM
ciccarp
18
Apr 9, 2011 07:15 PM
rsjohnsn
Modular V10 (6.8l)
Apr 8, 2002 04:36 AM
