Sponsored by: Auxito
'99 Expedition Automatic Leveling System
Old Feb 18, 2009 | 10:19 AM
FourthFordTruck's Avatar
FourthFordTruck
I have a '99 Eddie Bauer Exp., 5.4 4x2 with 122,000. The Auto Leveling System (not sure if that's the name) constantly kicks on with no result, the truck is listing to the right (starboard). It's supposed to kick on when starting vehicle or when parked on an uneven surface. Thanks. Also, can anyone give me the exact measurements or name of the engine mount bolts, my '97 4.6 has none mounting the enging to the brackets so the engine raises up when accelerating. None of the dealers have them which is hard to believe.
Old Feb 18, 2009 | 10:48 AM
KingRanchMan02's Avatar
KingRanchMan02
The guys in the Expedition forum will be a lot more help on this for you.
Old Feb 18, 2009 | 03:30 PM
FourthFordTruck
Thanks. Can you answer the question about the motor mount bolts?
Old Feb 18, 2009 | 04:19 PM
KingRanchMan02
I have never had one of these engine mounts in hand but, most motormounts that I have had in hand have studs that are welded to plates that are then molded in rubber. With this in mind, I would say that you need a new motor mount. Try searching for it on this website. They are a sponsor of FTE. Good luck!
http://www.discountfordpartsaty2kford.com/
Old Feb 19, 2009 | 04:03 PM
FourthFordTruck
This one actually has bolts that are missing. The dealership has a diagram but they can't seem to differentiate between the 4x2 and the 4x4. Any one know?
Old Feb 19, 2009 | 04:24 PM
KingRanchMan02
Have you tried contacting the sponsor through their contact us page? They may be more knowledgable than your local dealer parts guy. Good luck!
http://www.directfordparts.com/storefront/index.cfm?action=contactus&siteid=214290
Old Feb 26, 2009 | 08:03 PM
FourthFordTruck
They are 10mm bolts. Ford wants 5.86 a piece, I found them for .50 a piece at local supply.
1978Quinn
Oct 14, 2016 10:15 AM
smalls7676
Nov 5, 2014 09:23 AM
cay5628
Jun 14, 2013 11:03 PM
jayjayhub
Nov 3, 2005 11:49 AM
