kjett - 3k lbs?!?! I sure wish I was that light, I'm at a shade over 5k right now. Hopin to do some sorta diet plan on the truck but still have it look normal from the outside.
Thanks everyone, I'll keep ya posted on progress, changes and such as I get this winter mod frenzy movin along!!
trying to go for the tunnel ram look?? lol damn i'd think you'd start to lose hp after about a 2in spacer and those are some THICK header gaskets your using
^^^ it's a 2" cloverleaf and a 1" 4 hole. It's to help promote better fuel swirl and increasse the air/fuel velocity when running a dual plane intake.
The headers actually have a 3/8" spacer between them and the heads. Its to give me a smoother transition between the max ported D3 heads and the 2 1/8" tubes.
bartn98 - I am running moser shafts in the rear 60. No problems so far but they are only 30 spline 1" shafts so I have my fingers crossed LOL. The stock ones lasted awhile but once I stepped up to a healthy big block, it wasnt long before they gave up on me.
It's a race motor thing. You won't see that on your normal street motor. They are crankcase evac tubes that use the exhaust flow to suck the gases out of the crankcase.
I'll be running those on my new build as well, not sure if they help alot, but I know they do work. They're also supposed to help keep the piston rings sealed so that you don't lose compression to blow by.
