anyone use a K&N Air Charger? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Reload this Page >
Old 02-15-2002, 07:32 PM
fortythree
fortythree is offline
fortythree is starting off with a positive reputation.
well, i was thinking of trying one out because they say it is the off road equivelent of a FIPK (basically the same but for trucks without mass air)...
anyone use one before? notice any +/-'s?
one thing i wonder about, is that these "kits" or intake filters are open to take in the air (warm) from the engine... but a normal panel filter that sits in the air filter box takes in air from the inlet which is close to the radiator (cooler)...
anyways, any suggestions, comments, ideas, etc., muchly appreciated.
thanks in advance
Old 02-16-2002, 10:32 PM
1-ton
1-ton is offline
1-ton is starting off with a positive reputation.
I had one on my '90 with a 351, I could tell very little difference if any.:-X23 But hey, it looked cool!
Old 02-17-2002, 11:51 PM
Cope
Cope is offline
Cope is starting off with a positive reputation.
Does anyone have an FIPK on a 4.9? I've considered getting one to see if it makes any difference in throttle response or fuel mileage but I've also speculated about the possible warm air side effects.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old 02-19-2002, 06:23 PM
Drawsoncad420's Avatar
Drawsoncad420
Drawsoncad420 is offline
Drawsoncad420 is starting off with a positive reputation.
Old 02-21-2002, 12:30 AM
thewhiteford
thewhiteford is offline
thewhiteford is starting off with a positive reputation.
Cope, I had a K&N FIPK on my '95 F150 4x4 with the great, straight 6. I installed it at 24000mi. I felt an immediate difference. It definately helped the engine breathe better and my butt-o-meter told me it worked, too. I'd suggest using it. It works.
However, I installed the same kit on my '01 SD and felt hardly any difference. That was at 9000mi. When it's cold out, below 40, then the K&N seems to make a difference. I'm hoping it will fit together like a formula when I get the exhaust done. Hoping anyway. I'm betting on the engine breathing better at both ends will do more than just one. But for the I6, the stock exhaust was probably already large enough that it didn't need to be opened up anymore.
Just my 2 cents. Good luck.
Old 02-21-2002, 12:51 AM
Cope
Cope is offline
Thanks. I think I might give it a chance.
Cope
95 F-150 4x4
4.9L M5OD
Warn Premiums
shockr
EcoBoost (all engine sizes)
20
09-14-2013 03:08 PM
Links_vette
04-13-2009 09:12 PM
6686L
06-23-2008 12:24 PM
JohnAW
Air Intakes, Air Filters & Ram Air
03-30-2008 01:08 PM
pickupman2002
10-12-2005 05:09 PM
Quick Reply: anyone use a K&N Air Charger?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
