Just priced Line-x is it really worth it????
Hey all. Both Line x dealers close to me are stating $445 for the bed sprayed under rails (8 foot bed) and an additional $175 for linex xtra. Is Line-x really that much better than rhino? I heard rhino's easy to rip so that is why I was going with line -x. Any suggestions?? $620 is a little steep in my opinion.
I've not owned the truck since new, but I've not seen any fade since I've had it (2.5 years). I don't have a bed cover so it's out in the elements all the time. Now, keep in mind that I'm in Seattle and sunshine is a rare commodity 9 months out of the year!
I think Line-X is a great product. I had Rhino on my last bed and Line-X on this one. I dropped a draw bar on the Rhino'd tailgate and ripped the application. Comparing Rhino and Line-X on my trucks and others, the Line-X isn't applied as thick (so it looks better) and is more durable. I started looking because I thought that maybe the thickness of the coating varied from shop to shop. It seems consistent that the Line-X is applied more thinly and therefore is more tear resistant? It does look better IMO. Also, the Line-X shop removed the bed bolts and tie downs before spraying where as the Rhino shop sprayed over them. I recommend you request that to be done. The technician said it's a bear to remove the bed if the bolts are sprayed over. Chances are you won't ever remove the bed but who knows?
According to the technical data sheets:
LINE-X has a 31% higher tear strength than Rhino Tuff Grip and Hardline.
LINE-X has more than double the tear strength of Rhino Tuff Stuff.
LINE-X Xtra is an optional add-on product. The benefits are: Resists fading and loss of gloss, is more stain resistant, is more chemical resistant, is easier to clean, is fortified with a DuPont Kevlar micro pulp for durability. Xtra is available in any color.
