Who has the most miles on their V10?? - Page 15 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
  #211
Old 04-30-2017, 02:52 PM
azcactus
azcactus is offline
azcactus is starting off with a positive reputation.
2000 excursion 315,000. original engine, tranny rebuilt 2 years ago.
  #212
Old 05-08-2017, 11:38 AM
robj1999
robj1999 is offline
robj1999 is starting off with a positive reputation.
Not the most...
1999
17 years
205000 miles
250 cc LB 4x4
changes plugs 3 times
got 60k out of the last set of BFG KO, trying yokohama geolanders now, liking them
replaced the alternator some time back
replace the radiator recently (change coolant 4 times)
replaced both front hubs some 10 years ago(carry a spare in the truck)
replaced some of the coils
brakes and rotors several times
replaced the injectors (didn't really need to, tracing a problem)
replaced the injector plugs(see above)
3-4 battery's
my cd player quit last year
I fixed the overhead console(temp mileage, etc) via ebay for $25
Flushed tranny at about 80, due for another
  #213
Old 05-11-2017, 02:23 AM
itsnotrocketscience
itsnotrocketscience is offline
itsnotrocketscience is starting off with a positive reputation.
[QUOTE=robj1999;17174808]Not the most...
1999
17 years
205000 miles
250 cc LB 4x4
3-4 battery's
Flushed tranny at about 80, due for another[/Q
  #214
Old 05-12-2017, 04:11 PM
Lawn Enforcement
Lawn Enforcement is offline
Lawn Enforcement is starting off with a positive reputation.
I've got 245,000 on my 05. Repaired the ball joints and the alternator and that's about the only thing that has gone bad so far... Oh yeah and the rust around the wheel wells
  #215
Old 05-12-2017, 09:45 PM
'88 E-350
'88 E-350 is offline
'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.'88 E-350 has a good reputation on FTE.
The PO of mine replaced the engine just shy of 200k, it was still running fine but he overheated it and blew a head gasket. Rather than "fix an old motor" he dropped in a new crate motor. It's got about 40K now so I've got a long way to go.
  #216
Old 05-28-2017, 04:37 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
I just turned over 300,000miles couple days ago.
  #217
Old 05-31-2017, 04:10 PM
Sand_Man's Avatar
Sand_Man
Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
Mine just turned over 171K a couple weeks ago. This has been the single most trouble-free vehicle I've owned or heard about in my life. So far, it's required a battery, alternator one plug blew out about 70K ago and I replaced all the plugs, boots and one coil at about 150K. That's it aside from "consumables" like brake pads and tires. By doing regular oil changes, including the trans the thing drives as well as it did when I first got it in '09. By keeping it clean (it is my daily driver) inside and out, the paint looks great, much better than my friend's '12 Dodge. I think this is a real testament to the quality of Ford's paint. The interior has held up well with the exception of the steering wheel. I plan to have it and the front seat bottoms re-covered in the coming months which will have the inside looking new again. Couldn't be happier and plan to keep it forever.
  #218
Old 06-01-2017, 09:45 AM
Robv2346's Avatar
Robv2346
Robv2346 is offline
Robv2346 is gaining momentum as a positive member of FTE.
same story on my 2003 179,000 except no blown plugs. Threw first code at 170k. Rear door rockers showing rust. Using Mobil 1 high mileage every 5k. Just did shocks rear u joint.
  #219
Old 06-14-2017, 08:08 PM
Aune163
Aune163 is offline
Aune163 is starting off with a positive reputation.
On my 3rd super duty v10. First one i traded in at 213k. The next one i bought at 220k. I just traded it in at 235k for a 2008 v10 F350 with 146 on the clock.
  #220
Old 06-21-2017, 03:03 AM
550hauler
550hauler is offline
550hauler is starting off with a positive reputation.
204,000 miles
f550 with 204,000 miles, but... 14,397 hours due to pto. if you averaged 40 mph for 14,000 hours that would be 560,000 miles , and the truck weights 13,800 on the scale. still runs strong. need to clean rad though fan runs too much.
  #221
Old 12-17-2017, 10:00 PM
priusklr
priusklr is offline
priusklr is starting off with a positive reputation.
Replacing a fuel pump
Why remove the tank?
My 1999 Lexus RX 300 has an access panel for the fuel pump/sending unit under the rear seat.
My 2000 excursion with 293,892 miles refused to start. I replaced the relay. Replaced the fuel filter.
No fuel flow when the line to the filter was disconnected and attempted to crank.
Inertia switch check out.
Dead fuel pump:: -arrgh
So I made my own access panel. I simply cut out the bed above the center of the tank with a cut-off disc on a 4" grinder. Make sure to cut very SHALLOW. Just behind the cross member. Easy access to the unit. No need to possibly damage any of the hoses or electrical connections especially due to their age. I then placed a fire retardent fabric under the cut-out so I could weld the cut closed. then I removed the fabric. The access panel is under the carpet. No Body Knows. Yes you can make it removable with hinges , screws etc. for future use.
KISS - keeep is simple s?????
This took approximately 45 minute to complete.
  #222
Old 01-11-2018, 10:11 PM
blueovalman
blueovalman is offline
blueovalman is starting off with a positive reputation.
344,000 miles on my 2003 F250 SC 4x4 V10 6-speed. Still runs like a top. Motor is all original other than spark plugs and oil. Spent the first half of it's life as a tow vehicle hauling livestock, hay, farm equipment, etc. Now it's my daily driver farm truck. Still pulls fertilizer buggies, combine heads, seed trailer, and whatever else is needed. Couldn't ask for a more reliable truck.
Joe
  #223
Old 01-11-2018, 11:39 PM
Keeth
Keeth is offline
Keeth is starting off with a positive reputation.
300,000 Miles on my 01 F350 dually before it finally jumped time and destroyed a piston. Needless to say i bought another motor from an 00 excursion for 800$ and dropped her in over a weekend. Back on the road.
  #224
Old 01-12-2018, 07:56 AM
halvy
halvy is offline
halvy is starting off with a positive reputation.
Lots of miles
This may not be the most miles, but my 1999 F350, 6.8L, DRW, extended cab has 418,350 miles on the counter. Engine has never needed to be opened and is still running very well. Transmission has never needed to be opened. This truck just keeps going, and going, and going. This truck has pulled my 12,500# 5th wheel at least 80,000 miles from coast to coast and North to South.
  #225
Old 01-23-2018, 09:30 AM
johnfist
johnfist is offline
johnfist is starting off with a positive reputation.
I think this wins on straight miles. Congrats, hope mine lasts that long (2008, 141k miles).
Quick Reply: Who has the most miles on their V10??
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
