1996 f250 problem
Old Feb 16, 2009 | 01:47 PM
aderondaksnowremoval's Avatar
1996 f250 problem
i have a 1996 f250 with the 351w and a e4od trans. i cant get the thing to run right ? iv changed the cap, rotor ,plugs ,wires ,air mass sensor ,temp controll sensor ,some days it runs perfect no problems certain days it runs like crap , it boggs down wont shift right very doggy and sometimes it clears out then comes back. it is driving me nuts cant figure it out. i have a coil to put in it, but i dont think thats it. any ideas or help would be awsome plz reply thanks
Old Feb 16, 2009 | 02:24 PM
Blue Rebel's Avatar
Blue Rebel
Change the fuel filter and coolant temp sensor. Changing these 2 things always results in smoother operation.
Old Feb 16, 2009 | 05:14 PM
1996 f250 problem
i changed the coolant sensor for the computer and the fuel filter already and still having problem this one has me stumped any other ideas plz help
Old Feb 16, 2009 | 05:56 PM
would the tps or the iac cause this problem and how could i tell if it is one of them thanks
Old Feb 16, 2009 | 06:38 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Pull the codes, this will hopefully find the problem for you and keep you from throwing parts at the truck.
Old Feb 16, 2009 | 06:41 PM
BRay09's Avatar
BRay09
I agree with 1994 F250: 351, C6. Pull codes. Also could be a clogged muffler/exhaust somewhere. That may couse some of your symptoms also.
Old Feb 16, 2009 | 07:14 PM
i had ford put it on there computer and it said bad air mass sensor and 02 sensor. iv fixed both and still no change there were no other codes im wondering if it is the tps any other info would be great anyone work for ford in here lol thanks all
