Another blinker question
Old Feb 16, 2009 | 04:29 AM
blown86gt's Avatar
blown86gt
This time its a 2000 expy eb. The blinkers started to intermittenly not work, now they pretty much don't work all together. I am thinking the actual switch, but wanted to check with you guys first to see if anyone had this issue and what the correction was?
Thanks
Tommy
Old Feb 17, 2009 | 02:33 AM
c_hohensee's Avatar
c_hohensee
The first and easiest thing to check is the flasher unit after checking that you have no bad bulbs. You will find the flasher in the fuse block. The multi-function switches (turn signal, wipers, etc.) have been known to wear out. I have replaced them on both my mustang and my expedition. They are not that hard to change. The one for the expy was about $110 if I remember correctly.
Old Feb 17, 2009 | 04:23 AM
blown86gt's Avatar
blown86gt
thanks for the direction I will try to take a look tonight.
Old Feb 17, 2009 | 05:43 AM
shorebird's Avatar
shorebird
Fluid level. Definitely the Blinker Fluid level.
Sorry, I just couldn't resist the opportunity.
Old Feb 17, 2009 | 12:53 PM
blown86gt's Avatar
blown86gt
How do you check the blinker fluid level? I think it may also need exhust bearings too as there is a whine coming from around the tail pipe????
Old Feb 17, 2009 | 01:40 PM
alloro's Avatar
alloro
The fill hole is an unusual size, so you have to go and get yourself a metric adjustable wrench to remove it and look inside.
Old Feb 18, 2009 | 06:19 PM
blown86gt's Avatar
blown86gt
I got the metric adjustable wrench, it's a stainless steel one, but I dropped and it fell inside the a-arm, gotta pick up a stainless steel magnet to get it back out...
Old Feb 18, 2009 | 07:49 PM
alloro's Avatar
alloro
A magnet might stick to the a-arm, so you're better off borrowing a sneu to get it.
Old Feb 20, 2009 | 04:34 AM
blown86gt's Avatar
blown86gt
back on a serious note, I haven't had a chance to check the flasher unit, however found out last nigh that the brake lights are not working, the 3rd mount light works, but the 2 on the sides are not....
Old Feb 20, 2009 | 09:47 AM
alloro's Avatar
alloro
Well if it's not the flasher unit then it's your turn/multifunction switch. The 3rd brake light bypasses the switch because it doesn't blink for turns. The two lower brake light do pass through the switch. Since you're only having problems with those two that pass through the switch then that's where your problem is. I'm not 100% positive but I'm pretty sure that with a bad flasher unit the brake lights would still work, leading me to believe that the TS switch is ultimately the problem.
Old Feb 20, 2009 | 10:21 AM
blown86gt's Avatar
blown86gt
beings as it's the more expensive of the 2 things, I'm sure thats the problem. I am going to try to swap the flasher unit with the 1 from my 98 expo hopefully? there the same. Is there any way to check to see if it's bad? Ohm it out or anything?
Old Feb 20, 2009 | 11:34 AM
alloro's Avatar
alloro
Nope, these days the flasher units are electronic not mechanical. You would actually have to connect power to it and see if the output pulses +12v.
I don't have a wiring diagram for 2000 but assuming the diagram for my 97 is at least similar, the brake circuit will work even if the flasher is no good. The two lower brakes lights will definitely not work if the TS switch is bad. I'm like 99% sure the TS switch is your problem.
Old Jun 12, 2009 | 10:50 AM
SShank42's Avatar
SShank42
I'm having exact same problem on an 01. Got in it and heard this clicking sound coming from under the dash/steering wheel area. It was a little black box to the right/pass. side of the steering column. It had a relay in it that was clicking in and out. Replaced it. Then later that day noticed no turn sig. and no lower brake light. Is there anything else besides the turn switch to consider? Thanks
Old Jun 12, 2009 | 11:20 AM
alloro's Avatar
alloro
I don't think the flasher unit is under the dash. It's in the fuse box...isn't it?
Old Jun 12, 2009 | 11:54 AM
SShank42's Avatar
SShank42
Probably. I changed a relay. After the change the clicking stopped. So it seems I did something correct. Don't know if the brake lights/turn signal worked before I changed the relay or not.
