1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Death Wobble HELP
Old 02-04-2009, 11:58 PM
Fire1rescue64's Avatar
Fire1rescue64
Fire1rescue64 is offline
Question Death Wobble HELP
I own a 2007 f250. I had it for about 2 months and no wobbles. I recently put a 9 inch lift with 3 inch spacers on 40 inch super swampers. Since the lift i have a death wobble from 42 to 49 mph. when it gets into the wobble its undriveable. ball joints are good tires are balanced multiple stabilizers installed any direction to possiby check would be awesome. sometimes i can break the 48 mph zone and ride fine but very very rarely
Old 02-05-2009, 12:02 AM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
Stock steering?
If so that's very dangerous as it's at an extreme operating angle if all you have is a drop pitman arm.
Personally, I would not drive the truck......not going to be pretty if the drag link fails.
What's the caster setting?
Have you had it aligned?
What is the lift composed of (what brands and parts)?
Does it wobble all the time at that speed? Or only when hitting a bump?
Old 02-05-2009, 12:11 AM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
pics of ur front end setup would really help to...
Old 02-06-2009, 05:21 AM
supeRobertduty's Avatar
supeRobertduty
supeRobertduty is offline
Only 2 things changed after your lift : Tires and the Caster.
#1 - install stock tires and drive
#2 - Have Caster checked
#3 - Have Tire's balanced and Caster re-set that should do the trick (if nothing is worn out)
p.s : the toe and camber stay the same after a lift , The toe will change with tire size.
Old 02-16-2009, 09:47 PM
minguez78's Avatar
minguez78
minguez78 is offline
fixed the death wobble!!!!
man what a releif, i've lived with that wobble for 2 years now and finnally figured it out. i bought these new castor shims or whatever there called and had them installed. i swear its like i have a brand new truck. its an 06 F250 XL 6.0, 6in pro comp stage 1 lift. it cost me $250 to have it realigned and the new shims put in. it might seem like a lot but i was about to pay $850 to have the lift taken back off and stock parts reinstalled!
Old 02-17-2009, 01:05 AM
BeerMeNow's Avatar
BeerMeNow
BeerMeNow is offline
2 YEARS!! are you kidding? Totally unsafe and are lucky if it has not screwed something else up in the meantime.
Old 02-17-2009, 08:52 PM
minguez78's Avatar
minguez78
as of right now i dont think anything else is messed up, i was always getting under there to check for loose or worn parts as much as possible. i had the problem for 2 years, but i was deployed for 1 year of that and it didnt get driven at all during. i actually got the idea to change the castor from this site. so i thank everyone for the knowledge i acquired from here!!!
Old 02-17-2009, 08:53 PM
DCSpecial's Avatar
DCSpecial
Very common....05+ SDs are pretty sensitive to caster settings.
IMO, the caster is a little bit low in stock form. But that is just my opinion.
Old 02-18-2009, 12:54 AM
BeerMeNow's Avatar
BeerMeNow
OK that sounds better, Glad to hear your back!!
bergysport
1983 - 2012 Ranger & B-Series
05-13-2014 12:54 PM
White Boy
1978 - 1996 Big Bronco
04-07-2014 05:34 PM
sglass57
6.4L Power Stroke Diesel
06-26-2013 10:17 AM
captain1997
09-18-2011 05:33 PM
bkpatton
02-22-2010 07:15 AM
Quick Reply: Death Wobble HELP
