changing fluids
Old Feb 14, 2009 | 03:41 PM
cole96's Avatar
cole96
changing fluids
i have a 95 ford f250 with a 5.8 im going to be changing the rearend gearoil , how much gear oil do u need is there a side fill plug ? the tranfer case what type of oil should i use? and same on the tranny it has a zf 5spd thanks
Old Feb 14, 2009 | 03:47 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
The fill plug on the 10.25" is on the driveshaft side of the pumpkin. I believe it is on the the driver's side. Buy a few quarts of fluid and fill it until oil starts to flow out of the fill hole.
The BW 1356 takes ATF.
The ZF5 uses ATF as well.
Old Feb 15, 2009 | 06:55 AM
EPNCSU2006's Avatar
EPNCSU2006
This from the ZF website: "ALL S5-47 GAS SPEC.TRANSMISSIONS USE DEXRON III / MERCON XT-2 QDX OR DDX."
