Hood Lift Support - 10th Gen F150
Old 03-30-2022, 11:00 PM
F150_4x4's Avatar
F150_4x4
F150_4x4 is offline
How do you change the hood lift support's on a 10th gen F150 ?
is it difficult ?
link to part: https://www.rockauto.com/en/moreinfo...pt=1404&jsn=13
Old 03-31-2022, 04:35 AM
manicmechanic007's Avatar
manicmechanic007
manicmechanic007 is offline
Received 1,039 Likes on 942 Posts
Real easy
Support the hood or have an assistant hold it
Remove the little clips at each end of the supports
They pull right off once the little clips are removed
I use a little pocket screwdriver or a pick tool and just pull the spring loaded clips straight off
The following 3 users liked this post by manicmechanic007:
Old 03-31-2022, 11:39 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Johnny Paycheck is offline
Exactly. If no extra hands around, a 2x4 to prop the hood up will work. I think that’s how I changed mine out at work after hours...
The following users liked this post:
Old 03-31-2022, 01:43 PM
F150_4x4's Avatar
F150_4x4
F150_4x4 is offline
Thanks bros.
Old 04-01-2022, 03:09 PM
Airborne 82nd's Avatar
Airborne 82nd
Airborne 82nd is offline
Ten minute job do ONE at a time.
Old 04-01-2022, 06:38 PM
WWR's Avatar
WWR
WWR is offline
You can buy actual hood props. Not bad to have if you wrench on a lot of different vehicles. Pro techs learn to not trust hydraulic struts because they sometimes hold.....until they don't (when you're under the hood)
Here's the Lisle I have. As of time of posting there's an AWD (Amazon Warehouse Deal) for $27....not bad. If it's somehow faulty Amazon will take it back on their dime......
https://smile.amazon.com/Lisle-45900...s%2C226&sr=8-4
I order way too much from Amazon on Warehouse Deals....typically the "used" actually means damaged packaging or open-box
Old 04-02-2022, 01:23 AM
Airborne 82nd
I will use my rifle mono-pod when changing out the hood struts. If you don't trust your hood struts then it is time to change.
WWR
Old 04-04-2022, 10:07 PM
truckguy92's Avatar
truckguy92
truckguy92 is offline
We’re the original hoods aluminum? I ask because my hood lifts have to be replaced as well since it tries to fall on me and my magnetic flashlights won’t attach the the hood. I see options on rockauto for steel and original, just want to order the correct parts the first time around.
Old 04-05-2022, 12:33 PM
WWR's Avatar
WWR
WWR is offline
AFAIK all OEM was aluminum.
Old 04-05-2022, 10:10 PM
truckguy92's Avatar
truckguy92
Good to know! I was surprised when I found out mine was.
ulmapache
07-01-2020 12:25 PM
metronome
1999 to 2016 Super Duty
03-10-2015 01:28 PM
FordYoungGun35
09-14-2012 02:27 PM
bigtexan99
02-13-2011 12:31 PM
Quick Reply: Hood Lift Support - 10th Gen F150
