fuel injectors on 04
x2 with 4doorsr
but to answer your question, check the part #'s. You'll find what you are describing is the case for almost everything for our trucks. It's because Ford offered 2 completely different F-150's in 2004.
So most places say 05-08 models to cover their butts...even if the part is 100% correct for a 04 new body style.
The 2004 F150's had fuel injector problems. There are multiple TSB's on free replacemt, up to Engine replacement, due to leaking injectors, causing hydrolock.
You should check into these if you are having problems. First go to a good local mechanic to diagnose your problem, pay him for his diagnose, then go to your dealer to have them replaced free.
I should have gave some back ground.
the truck has 140,000 miles on it, and idles offen as I use it as my office at work. I have had hard starting for a week now and is getting worse.
I,m changing the fuel drive mod tonight and fuel filter.
Yea I know it might also be the fuel pump. In the morning I will pull the fuel rails and see if they are seaping. I try to do all of my on work unless I have to. I don't trust the dealers as far as I can throw them.
thanks guys I,m just tring tocover my bets
