Is it difficult to remove a hard tonneau cover ... - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Reload this Page >
Old 03-02-2002, 02:17 PM
iradi8
iradi8 is offline
iradi8 is starting off with a positive reputation.
Post Is it difficult to remove a hard tonneau cover ...
on an F-250? I will be buying either a 5th wheel or a travel trailer soon. If I go with the 5th wheel I will have to remove the hard tonneau cover every time we go camping. How difficult is this to do? Can my wife and I do it? Any tips on getting it on and off easily and/or how to store it?
Thanks!
Old 03-03-2002, 07:15 PM
dust3
dust3 is offline
dust3 is starting off with a positive reputation.
Depends on what brand but most are easily removed and replaced by two people. As for storing it be very careful because it is a painted surface.
Old 04-04-2002, 02:53 PM
pilot10
pilot10 is offline
pilot10 is starting off with a positive reputation.
I helped a friend put one on a Ranger about a month ago. We took it off a couple of times to adjust the mounts and it was pretty easy. Other than damaging the topper when moving/storing my biggest concern would be the mounting points. On the Ranger we used sheet metal screws(the ones included w/ the install kit)and I think you only get a couple of mounts/remounts before the screw will float in the hole. So if you do take it off it might be best if you leave the mounting hardware in place. Using nuts and bolts would solve that issue but getting the nut on the bolt may be challenging due to the limited space inside the bed rails.
Tim
Old 04-14-2002, 07:24 PM
Drawsoncad420's Avatar
Drawsoncad420
Drawsoncad420 is offline
Drawsoncad420 is starting off with a positive reputation.
Old 10-14-2002, 05:05 PM
be4ja
be4ja is offline
be4ja is starting off with a positive reputation.
The hard cover I have you would not even have to remove. ITs called a Retrax. I found this cover at rolltopcover.com. It is made of a hard plastic, that rolls up into a canister in the front of your pickup. You should not need to take it off, but if you did it would take two guys about 30-45 min.
Phil
Old 11-25-2002, 10:52 AM
dynolock
dynolock is offline
dynolock is starting off with a positive reputation.
Roll up covers are the best way to go. They are easy to move out of the way when you want to haul stuff. Look at truckgadgets.com and they have lots of stuff like that. ED
rockymtns
2017+ Super Duty
15
06-08-2017 02:22 PM
acf6
1999 to 2016 Super Duty
39
04-06-2017 09:17 PM
Greengas
2017+ Super Duty
23
12-02-2016 07:08 AM
crazypopie1
21
04-28-2016 06:15 PM
Casey_78
2009 - 2014 F150
08-21-2015 07:32 PM
Quick Reply: Is it difficult to remove a hard tonneau cover ...
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service About Us
© 2018 MH Sub I, LLC dba Internet Brands
