Schaffers transmission fluid???
Old 02-10-2009, 10:38 AM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Anyone here run this in their auto trannys?
I'm gonna install a BTS VB and might as well switch to synthetic trans fluid.
If not Schaffers then what does everyone run?
Thanks in advance
Andrew
Old 02-10-2009, 10:56 AM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
I run Schaeffers in my BTS trans as that's what Brian recommended when I bought it.
Old 02-10-2009, 10:35 PM
jdecker88's Avatar
jdecker88
jdecker88 is offline
I do the same best way to go its about 75 bucks for a 5 gallon container.
Old 02-10-2009, 11:48 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
Schaeffer's has been in my BTS from day one. It's what goes in all of Brian's transmissions at the shop, as far as I know. He had several drums of it last time I was there. I've had no complaints from it, and I think it is contributing to my low trans temps.
Old 02-11-2009, 11:43 AM
strokersace's Avatar
strokersace
strokersace is offline
^^^ Same here in my '95 with the BTS tranny. That's what he trusts and puts in his built trannies. Brian has also said that Mobil fully synthetic ATF is a good product also. I put Schaeffer's in my stock trans last year, but when I thought I was having some trouble with the transmission, Brian said to just run regular ATF because the Schaeffer's is TOO slick for the stock clutches. I'll ask him about it more next week when I order my VB.
Old 02-11-2009, 02:01 PM
Bowie's Avatar
Bowie
Bowie is offline
just changed over to this stuff and it is working good so far
Old 02-11-2009, 04:28 PM
jrciii56's Avatar
jrciii56
jrciii56 is offline
I have been running Schaeffer Tranny fluid for about 70000 miles. I recently have seen my temps running a little warmer than normal. I will be changing it pretty soon. I hope to see those temps come back down.
Old 02-11-2009, 05:16 PM
HKusp's Avatar
HKusp
HKusp is offline
I'm running it blended with a bit of whatever else was in there that I couldn't get out with my failed tranny flush attempt. So far no problems.
darrelf150
Oil & Lubrication
05-28-2011 02:13 AM
rnolloth
07-03-2010 02:34 PM
case_7010
6.4L Power Stroke Diesel
08-24-2009 01:23 PM
Bird Dog
47
06-04-2009 08:13 AM
SPEC
01-27-2008 08:24 AM
Quick Reply: Schaffers transmission fluid???
