Master cylinder/brake line question
Does anybody know if these trucks have metric bubble flares on the master cylinder end of the stock brake lines?
Also does anyone know what size adapter I need for the front port on the master cylinder so I can just use a standard 3/16" flare fitting there?
They are not bubble flares, just a regular flare. I am not sure what size adapter you'd need, when I did my lines I re-used the nut from the old line.
To find out what adapter you need without having to measure, maybe your local parts store (I've found NAPA's to be very well stocked for adapters) will have a master in stock. If they do, you could always ask them to get you an adapter that fits the master and a standard 3/16 line.
Last edited by Bob Gervais; 02-09-2009 at 12:21 PM. Reason: added second paragraph
ManfredVonRichtofen
07-10-2016 11:24 PM
dmccorkle911
18
08-03-2014 03:24 PM
TerryW
07-20-2004 01:22 PM
Faithful Old Road Dog
06-17-2003 09:37 PM
