High volume fuel pump 95 150
Im going to put 255 lph fuel pump in.... I have done this on mustangs but the truck is a little deferant... I already took the front tank out some time a go so i just have the rear tank....But when i took out the front tank noticed the pump is incased in plastic.... Not sure if it comes apart ??? The mustangs didnt have this ..does any one know about this or has done one 95 150 302 EFI.... Thanks
maybe you could put one of those msd inline pumps right on the frame rail by the tank to help pull some extra fuel out instead of making a custom fuel pump holder thingie
http://store.summitracing.com/partde...5&autoview=sku
Ya im going to look in to that .mabee a mustang sending unit will fit with a little work....I just didnt know what the plastic was for ??. Thanks !!
MSD Ignition 2225 - MSD High Pressure Electric Fuel Pumps - summitracing.com
Conanski.. I found this site TRE Performance.com Tre-340 255 LPH pump for 90-96 f 150... 70 bucks....Im just wonder about how good it is ??? Or just get mustang sending unit... With good pump & make it work... I know you know alot about these trucks & motors.. so i trust your opinion...Bruce
the helper pump will actually increase fuel flow because it is reducing how hard the intank pump has to push the fuel through the lines making it more efficient. i did this to a 69 351 mustang that was using a fox body fuel injection system with a fox body style tank, the car was starving for fuel in 3rd and 4th gear at around 6000rpms and the pump solved this condition with out having to drop the tank. but i dont know how much your engine is really starving it's self, this one wasn't that bad but you could notice it start to break up around 6k and he shifted at 6500
so idk if that would help your problems or not
something else you could do is pull the intank pump and put a hose in it's place and just run a frame rail mounted pump this will work for sure just make sure that the pump is as close to the gas tank as you can because they are designed to push fuel down the lines not pull it
on
Here's the sending unit disassembled...
And here is a stock pump beside a 155L Holley, it's easy to see why it doesn't fit..
