Canola oil IDI
02-04-2009, 06:50 PM
on
Canola oil IDI
has anyone run a IDI on canola oil. i have access to a fare amount of used canola oil and i was thinking of running one tank of bio fuel and one tank of deisel. the truck is a 1992 turbo diesel.
02-04-2009, 07:08 PM
I would mix it 50/50 with diesel in one tank, make sure if its used thats its filtered really well. Depending on where you are, I wouldn't do it until summer tho. During the summer I put about 10 gal of cotton seed oil in one tank and it never had a problem with it.
02-04-2009, 07:10 PM
on
It will work fine, just keep one tank of "Clean" fuel to start and stop on. If your in cold climate you may need to blend the oil with diesel or kerosene to prevent gelling.
02-04-2009, 07:22 PM
on
what type of filters should i run. i would be running it only in the summer because the winter temps up here are around -20, -30.
02-04-2009, 07:49 PM
filter BEFORE putting it in the truck. I would first get a screen mesh filter from the fertilizer section from Tractor Supply, then I would filter it through a 2 micron fuel filter
02-05-2009, 06:43 AM
on
Everyone does it differently, some heat it some dont. I screen off all the big chunks then heat it before filtering then it goes through 2 1 micron house waterfilters back to back, and the final filter is a Goldenrod water absorbing filter.
Oh yeah even though your gonna run it in the summer, keep and extra fuel filter in the truck just incase.
02-05-2009, 06:57 AM
on
Water and injector nozzles don't go well together so as already said: getting as much water out as you can is GOOD!
Supercab
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-22-2009 10:21 AM
tamte65
15
07-03-2007 07:32 PM
Wheatina
05-15-2007 12:16 PM
VelocityDriver
15
05-21-2006 12:47 PM
94F250_weekender
04-27-2006 08:11 AM
