The API of SM is a rating for a gas engine. The S stands for spark ignition and the M is the rating. You need an oil with the CJ rating on it. The C stands for compression ignition as in a diesel engine. Most good oil have both ratings but make sure it has CJ or CJ-4, something like that. Some will say CI or CI-plus, don't use it! Stick with CJ
You can also use a 5W40 oil. Rotella, Mobil-1 (most commonly available) and others make CJ rated synthetic 5W40 oils. If you plan to tow any I would recommend this over a 10W30.
