DP tuner hurt motor?
Old 02-02-2009, 08:48 PM
Jbrown8988's Avatar
Jbrown8988
Jbrown8988 is offline
Jbrown8988 is starting off with a positive reputation.
i want to get a dp tuner but i have heard mixed stories. my truck has 140,000 miles on it will the tuner hurt my motor? i got gauges coming and stacks and plan on finding and intake. what do you guys recommend? and what is a 6630 mod?
Old 02-02-2009, 08:53 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
It is the intake filter- Napa Part # 6637
Old 02-02-2009, 08:56 PM
Jbrown8988's Avatar
Jbrown8988
oh so that is for the stock intake then?
Old 02-02-2009, 08:57 PM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
Its an aftermarket filter that fits onto your stock air intake hose when you remove the stock air box.
As long as you are responsible... The DP will only help your truck... not hurt it. I would be interested to know who you herd that it would hurt your truck. Non of those stories around here. Everyone LOVES their DP.
Old 02-02-2009, 08:58 PM
Jbrown8988's Avatar
Jbrown8988
oh ic. is it good to use with a tuner? or better to get a dif intake?
Old 02-02-2009, 09:01 PM
4inchlovin's Avatar
4inchlovin
The 6637 is comparable to most expensive intakes better then anything with K&N on it. And about 95% better then your stock one.
Izzy351's Avatar
Izzy351
Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
That filter will support a lot more HP than you'll be making with just a tuner.
It's BIG:
gmm's Avatar
gmm
gmm is offline
gmm is starting off with a positive reputation.
It is good with or without a tuner. It lets the engine breath a heck of a lot better than the stock air filter box. It also seals better, uses hose clamp for positive seal. No more dusting.
Old 02-02-2009, 09:03 PM
Jbrown8988's Avatar
Jbrown8988
so it looks like you remove the plastic housing then? how much is it?
Old 02-02-2009, 09:04 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Yep. Pull the stock box out, then just lay it in. It's about $35 delivered from FleetFilter.com. Go there and search for part no. 6637...
Old 02-02-2009, 09:06 PM
4inchlovin's Avatar
4inchlovin
I was looking for the pic of mine but seem to have lost it! Thanks Joe!
Jbrown8988's Avatar
Jbrown8988
Nobody on here just people around my town. a bunch of no it all's that don't know jack!
Old 02-02-2009, 09:08 PM
4inchlovin's Avatar
4inchlovin
Do a search for permagrin and or variations of that word and it will let you know how people like their dp's
Jbrown8988's Avatar
Jbrown8988
off topic how do i find out my ecu?
Old 02-02-2009, 09:13 PM
Jbrown8988's Avatar
Jbrown8988
isnt there a wire connected to the box though?
Quick Reply: DP tuner hurt motor?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
