Factory hitch and traler plug
Old 02-02-2009, 01:40 PM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
87 F-150 I6 has a good reputation on FTE.87 F-150 I6 has a good reputation on FTE.
Factory hitch and trailer plug
Ok so call me an idiot but the factory installed trailer plug is not hooked up. In order for me to get it working I would have to get a brake controller, right. Also, what it the load rating on that hitch?
Old 02-02-2009, 02:02 PM
gdn's Avatar
gdn
gdn is offline
gdn is gaining momentum as a positive member of FTE.
The factory plug should already be wired for lights but you do need a brake controller for your trailer brakes. The wiring should already be there at the plug and it dead ends up under the dash so installing the controller is pretty easy. It's been a couple of years since I put mine on but IIRC there is a wiring harness kit you can get that plugs into the factory harness and then you just wire to the controller.
Old 02-02-2009, 02:15 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Greg's got you set. You should have power to the 7 wire plug on the bumper just not the brake activation without having a controller. You can take a test light and check for lights, signals, brake lights etc.
Old 02-03-2009, 10:40 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
What they both said. Factory hitch is a class V 10K GVWR hitch.
Old 02-03-2009, 10:52 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
The wiring harness was in the glove box when I bought my truck new.
Old 02-03-2009, 10:57 AM
superduty4x4
The trailer wiring harness, or the brake control harness?
Old 02-03-2009, 11:03 AM
miller_feed
Sorry, didn't specify, brake control harness.
Old 02-03-2009, 11:11 AM
superduty4x4
Had me worried there Rick...
Old 02-03-2009, 11:16 AM
87 F-150 I6
All good info, Thanks all!
Old 02-03-2009, 12:18 PM
miller_feed
I put the goose neck hitch in my truck as soon as I bought the truck. The guy putting the hitch on went right to my glove box and took the harness out, he knew that is where Ford put them.
Old 02-03-2009, 01:04 PM
rebelchevy02's Avatar
rebelchevy02
rebelchevy02 is offline
rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.
If your having trouble with trailer lights, there are seperate fuses for them. Just because your tailights and turn signals work on the truck, doesnt mean the fuse isnt blown for the trailer ones.
Old 02-03-2009, 01:32 PM
superduty4x4
And they are under the hood, just FYI.
Old 02-03-2009, 02:53 PM
Ponyboychris
Hit it!
On Andrew's '02 (like mine), all the fuses are under the dash. I went through this when I bought my truck. All the trailer related fuses were blown. I think there were 3 of them.
Old 02-03-2009, 03:11 PM
rebelchevy02
I think thats how mine are, but there also is the battery charge maxi fuse, and trailer brake maxi fuse, and their relays under the hood. . Thats just not were the light ones are, but there are some under the hood.
Old 02-03-2009, 03:20 PM
superduty4x4
Well I was at least partially right My 99 has all the trailer fuses under the hood.
Quick Reply: Factory hitch and traler plug
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
