Starter Issue.
Old 02-01-2009, 05:40 PM
hellbound_redneck's Avatar
hellbound_redneck
hellbound_redneck is offline
Starter Issue.
I have put a 6 volt battery in my F-1, and when I try to start it the starter just spins. I am thinking that the battery may not have enough of a charge to kick the bendix in, but maybe someone has some other things to check?
Thanks for the help.
Old 02-01-2009, 06:00 PM
1955effie's Avatar
1955effie
1955effie is offline
yes , i agree make sure that your battery is at full charge . if that checks out you might have a bendix that may be sticking . you may have to take the starter out and clean the bendix drive . good luck ....
Old 02-01-2009, 08:02 PM
hellbound_redneck
Fresh new battery kicks it over, so that was my issue. now I just need to make it so the tank and the carburetor are connected... currently i am using a 12volt pump with battery to draw fuel out of a 1 gallon gas can and push it to the carb.
Old 02-01-2009, 08:33 PM
55 f350's Avatar
55 f350
55 f350 is offline
my old f-4 did that and the starter bendix took a dump . the new owner had the starter rebuilt and fixed the electrical gremmies and he's driving it . so i'd be willing to bet bad bendix .
Old 02-01-2009, 08:39 PM
hellbound_redneck
I am actually inclined to believe the battery that i had in it was no good anymore. the date code was only about 15 years ago, and it has been sitting for 10 of them.
g.logistics
12-17-2014 09:02 PM
pooneee
01-07-2014 01:46 PM
Frankiea87
12-26-2013 04:40 PM
quiacato
03-08-2011 10:16 PM
kjb304
1997 - 2003 F150
08-31-2008 08:50 PM
Quick Reply: Starter Issue.
