1987 Ford Truck 1Ton Need Lots of Help
We have fire to coil, but no spark to the distributor. There is a clicking noise by the Master cylnder, The truck will turn over but will not start.
We changed the ignition switch, Distributor cap, Distributor module, plug wires, and coil pack still no spark to the distributor. Help
<!-- / message -->
<!-- / message -->
<!-- controls -->
I've been doing some thinking about this. I remember many years ago, my '88 jsut quit running on my way home from work one morning. After letting it sit for a bit it did restart and I finally nursedit home. Once home it refused to start anymore. Had the ame symtems as your truck. Towed it to a local garage, where they found the computer went bad. After they changed that, I had no more problems with the truck.
Have you checked all your ground wires?
kc135cruechief
06-15-2007 05:55 PM
