signal light problems!
Jan 31, 2009 | 10:11 PM
it started out with the left signal flashing rapidly and i noticed that the front left signal wasn't working now nothing working no signals, brake lights or hazzards. I am wondering if the front left bulb burnt out and now its not completeing the sircut? i checked the #1, 20 amp fuse under the dash and it is good. where else could i look for problems?
Jan 31, 2009 | 10:16 PM
It sounds like a ground problem to me, if the fuse is good.
Change the bulb out that is probably the problem Russ.
Jan 31, 2009 | 10:21 PM
One bulb should not take out all your lights. I agree with Jim sounds like a grounding issue to me.
Edit: Check the fuse with an ohm meter to make sure it is good sometimes looks can be deceiving.
Jan 31, 2009 | 10:23 PM
i,m hoping that it is the bulb but it's too late and -30 celcius wind chill tonight! just thought i would do my homework on the computer first!
Jan 31, 2009 | 10:24 PM
am i checking the right fuse? #1 fuse under the dash, 20 amp?
Jan 31, 2009 | 10:26 PM
maybe it could be the flasher also? where is it located?
Do you have the owners manual? What year is your truck?
Quote:
Originally Posted by
Rus01
Jan 31, 2009 | 10:28 PM
yes have manual, thats the one telling me to check, but maybe there is a fuse under the hood i should be checking also?? 2001 f350 sd 7.3ltr
Jan 31, 2009 | 10:37 PM
#13 is for the stop lamps.
Jan 31, 2009 | 10:38 PM
#24 is also tied to the turn signals but not the hazards or brake lights.
