part number request please for an 89 F-150
i have a 1989 F-150 4x4 with the 300 6 cyclinder engine and 4 speed manual transmission. There is a relay that i believe is not working that is mounted left front inner fender. It right behind the box that hold the air filter.
There are a part number on the side of the relay that reads E3TB-9345
right below it, it say A4/8JC
May i ask, what does this relay do? Would it keep the vehicle from running, if it is bad?
Thank you for your time.. I hope you can help
i have a 1989 F-150 4x4 with the 300 6 cylinder engine and 4 speed manual transmission. There is a relay that i believe is not working that is mounted left front inner fender. It right behind the box that hold the air filter.
There are a part number on the side of the relay that reads E3TB-9345 right below it, it say A4/8JC
E3TB-9345-A4 / 8JC: Made the third week (C) of September (J), 1988 (8).
May i ask, what does this relay do? Would it keep the vehicle from running, if it is bad? (Yes, that is correct).
Actual Ford part number: F19Z9345A (replaced: E3TZ9345A) .. Fuel Pump Relay.
Application:
1983/89: E250/350 / F250/350 460.
1984/89: F150/250 / U150, all with 302 EF1.
1987/89: F150/350 / E150/350 / U150, all with 300 I-6. (and others thru the 1990's).
Available from Ford:
MSRP: $11.14 // FTEpartsguy.com price: $8.36.
btw: E150/350 = Econoline / U150 = Bronco.
Haydendh
10-13-2014 06:14 PM
javi2001
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-04-2008 09:57 PM
Desertwolf
06-21-2007 07:16 AM
