E4OD does not shift
Old Feb 1, 2009 | 05:27 PM
ford trans tech's Avatar
ford trans tech
the sensor is located in the rear axle , all models 92-97 4x2 or 4x4
the truck is also equipped with a PSOM , programmable speedometer/odometer module
the speed sensor feeds the abs and the PSOM , the PSOM then changes the signal and relays it to the PCM . or transmission control module if you like
a blown fuse to the PSOM could be the issue , or a shorted cruise control servo if yours is equipeed with one
after that you most likely have a bad PSOM
Old Feb 1, 2009 | 05:29 PM
ford trans tech
on the 4x4 models the the 4 low switch sends a signal to the processor indicating 4 low and the PCM changes the shift strategy based on vss and tach signal accordingly
danlee
196
Jul 7, 2023 08:40 PM
headleyj
Jul 9, 2014 02:56 AM
Brett1989
Dec 27, 2007 11:56 AM
Robbgt
Feb 12, 2005 06:19 AM
kunder54
All Things Towing
Jun 14, 2004 07:43 PM
