Oil foam under filler cap
Just purchased a 2003 Mercury Mountaineer with 4.6L V8. 42k miles. Engine and car beautifully detailed. I serviced the truck. Oil was dirty but no signs of water or foam. I did notice under the oil fill cap there was a small amount of a creamy foam. Any ideas what that could be from. I don't know how long the truck sat before I got it. Could it be from a PCV valve or maybe from when engine was detailed? Thanks in advance, Ray
My 2000 expy was doing that. Had me in a panic till I talked to a mechanic, he said the new engines make a lot of moisture and if you make a lot of short trips the engine doesn't get hot enough to let it evaporate. Talked to my wife and sure enough she had been making 2 or 3short trips a day between offices. She got a new job with a longer drive and the moisture went away.
Jetdad, See my post in the Expy forum. Exact same issue and i have pics, so let me know if its similar to mine.
Similar discussion as here, may be nothing.... check oil, change thermostat, etc. etc. Like you, I hope its nothing...
https://www.ford-trucks.com/forums/8...er-in-oil.html
Last edited by KR1; 02-11-2009 at 01:47 PM. Reason: not the waterpump... changed the thermostat...
