Conundrum
Old Jan 31, 2009 | 07:13 AM
megawatt00's Avatar
megawatt00
Originally Posted by HighOctane
OK fellas. I just checked the connection to the starter today, noticed it a little loose and scuzzy, went to tighten it to see how loose it was, turned the ratchet a couple times and the actual moment I could start to feel any torque the casing behind the nut began to crumble and crank before my eyes! The corrosion of the casing behind this connecting bolt was unreal. This is a Bosche remanufactured unit less than 11 months old!!!Thankfully it has a 2 year warranty, and I have a new one arriving tomorrow afternoon. This will hopefully be the problem, if not I have found and fixed what was a soon to be problem. I also hope this is not a warranty issue I will be dealing with every year! Anyone else seen this happening?
Originally Posted by ron's power stroke
use electrical grease when you put the new starter in..
What happened Ryan is electrolysis. This is a chemical reaction from dis simular metals makeing contact. Add this to the salt that they probably use on the roads where you are.
As Ron said you can use dieelectric grease, I use Noalox, you can pick it up at Home Depot or Lowes. It is an oxide inhibiting compound that works great.
Old Jan 31, 2009 | 07:51 AM
Kwikkordead's Avatar
Kwikkordead
I hate road salt.
Old Jan 31, 2009 | 08:05 AM
megawatt00's Avatar
megawatt00
Originally Posted by Kwikkordead
I hate road salt.
Your not the only one Dan!!!!
Old Jan 31, 2009 | 01:59 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Thanks guys. Reps to all who helped, except to those that I have to spread it around some first.
