ripping belts
Old Jan 25, 2009 | 08:39 PM
02superf2's Avatar
02superf2
ripping belts
i put a DP Tuner chip on ky 02 7.3 about 8 months ago and have had two serpentine belts slowly shread apart on me. thinking its juss a bad tensioner or pulley. but if anyone else is having this same problem lemme know your suggestion
Old Jan 25, 2009 | 08:50 PM
F350-6's Avatar
F350-6
Welcome to FTE. Have you tried putting on a pair of safety glasses and standing on the side of the truck to see if the belt is tracking straight at idle? What about watching the belt as someone revs then lets off the accelerator to see if the belt is jumping around any? A bad tensioner or pulley would be my first suspicion. If the tensioner is bouncing up and down too much that may give you a clue. You can also remove the belt and inspect ans spin the pulleys to see if any of them don't feel or sound right.
fxstbchopper's Avatar
fxstbchopper
Welcome to the FTE!! I would say you have a bad belt tensioner or miss aligned pulley.
