hard to open from inside
Old Jan 24, 2009 | 03:14 PM
69Black250's Avatar
69Black250
I've been noticin my door was getting harder to open from the inside and i have broken two handles off since then. Anybody else having this problem? Somebody i talked to from around here said a cable might be stretched but I have yet to take of the door panel and look.
Old Jan 24, 2009 | 03:53 PM
quicklook2's Avatar
quicklook2
you need a new cable.
Old Jan 24, 2009 | 03:58 PM
Jason Lewis's Avatar
Jason Lewis
Theres a thin pice of metal that over time gets week and brakes, you half to remove the door pannel and remove the door handle. i just got a bolt and washer to brace the hole and thin re bolt the handle.
Old Jan 24, 2009 | 05:20 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
If it already rip bracket? Weld or rivet steel on it?
I notice that one alway break. plus replace handle on 97 F250 HD because hard open plus it have TONS of dust cover. That was contractor truck so it get dirty tons.
Old Jan 24, 2009 | 08:01 PM
TNT1968's Avatar
TNT1968
69Black250 lubricate the spring and hinge points in the mechanism (Jason's third pic) and the door handle will work great. Use the fender washer and a nylock too and you'll be golden for years to come.
Old Jan 25, 2009 | 01:15 AM
tjwc1's Avatar
tjwc1
also may try pulling up op on your door when it is open , may have worn out hinge pine like mine has . I have to sh_t kick it to get out... haha
Old Jan 25, 2009 | 04:31 AM
fonefiddy's Avatar
fonefiddy
It's the cable
Get a NEW one. Anything form the junk yard will be stretched out also.
The pics/problem Jason posted can also be attributed to a bad cable. The more they stretch, the harder peeps pull on them. Thus, breaking the speed bolt.
