2004 f-150
Reg cab, Scab, Screw?
Scab and Screw its located behind the rear seat on drivers side.
this should help
https://www.ford-trucks.com/article/...2006_F150.html
this should help
This is what my manual says on page 108 for the 4th printing on 2006 models manual
KEYLESS ENTRY SYSTEM (IF EQUIPPED)
You can use the keyless entry
keypad to:
• lock all vehicle doors.
• unlock only the driver’s door.
• unlock all vehicle doors.
• program/erase the customer keycode.
• enable/disable the autolocking feature.
The keypad can be operated with the factory set 5–digit entry code; this
code is located on the owner’s wallet card in the glove box, is marked on
the computer module, and is available from your authorized dealer. You
can also create your own 5–digit personal entry code.
When pressing the controls on the keypad, press the middle of the
controls to ensure a good activation.that computer module I bolded is usually on the back wall of the cab...is yours inside the engine bay or something?
I went out and looked at my trucks PCM and there isn't a 5 digit code on it. is this code located somewhere else under the hood?
here is pic of my PCM from my supercharger install. the white areas are some things I had to write on it, but the rest is untouched.
keypad to:
Might be old timers disease, and I know I have slept since then but, I would not steer you wrong. At least, not on purpose. I never claimed to be the brightest crayon in the box (ask my wife, she will confirm that I am not) but, I'm sure thats where I got it. I know that I have never been behind the back seat and yes the PCM is under the hood. Please be aware that I am not trying to be argumentative (not my nature). I could be mistaken. It's a good thing that I am not the custodian of the launch codes.
sorry if I'm coming across as argumentative with you. I am genuinely curious. You'll see threads asking about where that code is about every other day on here...or how to remove the rear seats to get to that code.
so if you can find it under the hood, that would be alot easier for everybody
I posted a picture of the my PCM to see if that is where you got it from...or from another module under the hood
