Trans temp sensor problem?
Old Jan 21, 2009 | 05:43 PM
Joms's Avatar
Joms
'04-F250-6.0-85k. After warming up and driving about 15 miles the trans temp gauge will slowly rise like normal but then slowly go back down. After that the check gauges light with come on, and after about another 2-3 miles the tow/haul light will start flashing. The trans seems to work ok, the level is perfect, and it doesn't smell burt at all. After the truck completely cools down (overnight) it will work fine for another 10-15 miles and act up the same way again.
I am guessing a sensor problem but does anyone have any other ideas? I am probably going to have to take this to the dealer as it is probably over my head. Do you think it is an expensive fix?
Also, sorry if this has already been talked about, I attempted to search first but really didn't find anything like what this truck is doing.
THANKS!
Old Jan 22, 2009 | 06:04 PM
jerzydiver's Avatar
jerzydiver
Put a scanner on the OBDII and pull the codes once it start. This will be a place to start once we know the DTC's.
Old Feb 19, 2009 | 06:15 PM
Flobber's Avatar
Flobber
I have the same problem and it dont give DTC code at all !!
Old Feb 19, 2009 | 07:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When the tow/haul light flashes a code is stored in the PCM's memory. Many scan tools can't read Ford trans codes, but the code is there. You need a Ford specific scan tool to get it.
Old Apr 18, 2010 | 04:50 PM
08SUPERDUTYKING's Avatar
08SUPERDUTYKING
I'm having the same problem now.... anyone have this resolved or know what causes this? Is it just the trans sensor that went bad? How hard is it to swap it out? Any help is greatly appreciated!
Old Apr 18, 2010 | 05:09 PM
69cj's Avatar
69cj
In many, many past posts this problem has been the TFT sensor in the tranny. It is a temp. sensor. If the tranny is working good and the temp. is all over the chart or just going high and it has had regiular service, the TFT is the odds on culprit. Perhaps a tech would like to comment. From past posts it is not that difficult to change and not that expensive.
Old Apr 18, 2010 | 06:36 PM
ljutic ss's Avatar
ljutic ss
It's a 1 to 1.5 hour job changing the TFT sensor out. List price is around $70 and you don't need a internal filter or pan gasket. The end of the TFT sensor that plugs into the trans is T shaped with a O ring on it, so once you disconnect the wire terminal from it you turn it 90 degrees and pull it out grabbing it with a pair of needle nose pliers.
scooter71
3.8 & 4.2L V6
63
Jul 25, 2018 11:27 PM
GoCamping
Aug 7, 2014 11:02 AM
garydmundy
Aug 29, 2013 09:01 AM
cay5628
Jun 14, 2013 11:03 PM
mOROTBREATH
27
Jan 13, 2011 05:53 PM
