Worn out Stock Rims
Old 01-21-2009, 11:05 AM
RussB's Avatar
RussB
RussB is offline
Worn out Stock Rims
Hey guys.. Here are a couple pictures that I took of my stock rims that I run in the winter time ! The whole inside lip is worn off... It may be from running the bigger tires on a narrow 7.5" rim.. not sure.. I've never seen it before !!
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=208100&.jpg[/img
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=208103&.jpg[/img
Hope that worked !!
Old 01-21-2009, 11:07 AM
RussB's Avatar
RussB
RussB is offline
Check the back side of your stock rim if you're running bigger tires !!!!
Old 01-21-2009, 11:08 AM
jdecker88's Avatar
jdecker88
jdecker88 is offline
Wow how many miles did you have on those rims running what sized tire the 315s?
RussB's Avatar
RussB
RussB is offline
Old 01-21-2009, 11:09 AM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
How big of a tire were you running?
Old 01-21-2009, 11:10 AM
RussB's Avatar
RussB
RussB is offline
The truck has 270,000 Kms on it ! These rims aren't on all the time..... but a good portion of it they were !! Lots of miles with 285's on them... the last few months they've had 315's !!!
Old 01-21-2009, 11:13 AM
61 uni's Avatar
61 uni
61 uni is offline
Gotta love a truck that wares rimes out before wareing the truck out
Old 01-21-2009, 11:15 AM
jdecker88's Avatar
jdecker88
Yikes my truck has had 285s on for over 50-60K I hope that doesn't happen to me I have the same Lariat wheels.
Old 01-21-2009, 11:17 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Yikes... better check mine!
Old 01-21-2009, 11:18 AM
RussB's Avatar
RussB
RussB is offline
Look on the back side of the rims !!! You can tell if you have the problem without taking the tire off.. you'll see a thin lip of aluminum starting to peal off... The only reason I noticed is I went to rotate the tires and pieces of alumi was sticking out !!
Its a good thing to take a look at for everyone that is running stock rims with 285's or bigger !! Might leave ya stranded with more than one flat all at once !! The chances are slim.... but !!! I'd look ! I've never scene a rim to this in my time !!!!
Old 01-21-2009, 11:23 AM
superduty4x4
I'm gonna check mine right now...
Old 01-21-2009, 11:28 AM
F350-6's Avatar
F350-6
F350-6 is offline
Reps to you for pointing this out. My wife's truck has 285's. I need to check this tonight.
I wonder why the tire change place never noticed a problem when you got new tires?
Old 01-21-2009, 11:36 AM
RussB's Avatar
RussB
RussB is offline
Its my friends shop... I was there when we put the 315's on in November.... We didn't notice any sign of this problem ! Put about 8000 kms on the 315's went to rotate and there it was... big..... bold... and staring you in the face !!!
Old 01-21-2009, 12:50 PM
Rick2001's Avatar
Rick2001
Rick2001 is offline
hmm guess I'll have a look at mine too
What is the theory to the issue?
Old 01-21-2009, 01:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
That's even more scary they can get that bad that quick.
